JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Project: DIY Supercharger
Pages (15): Previous 18 9 10 11 1215 Next
daveo
13-02-2020, 08:13 AM
#91
any update on this thread....its been 6 months :ohmy:
daveo
13-02-2020, 08:13 AM #91
14-02-2020, 08:30 AM
#92
not really no, we still await for someone with a charger to lend the cradle
this is and will continue to be the stumbling block for this build
14-02-2020, 08:30 AM #92
cornishlexus
14-02-2020, 02:18 PM
#93
do lexus sell it seperatley have you spoken to any one in lexus uk about sourcing one for you is maybe beta than asking a main dealer the part number for the cradle is AM27964
cornishlexus
14-02-2020, 02:18 PM #93
daveo
15-02-2020, 12:13 AM
#94
do you know if a tte supercharger has same mountings as the eaton m62 as i might be able to measure one up.
daveo
15-02-2020, 12:13 AM #94
15-02-2020, 04:35 AM
#95
daveo do you know if a tte supercharger has same mountings as the eaton m62 as i might be able to measure one up.
Yes it does, I even have a broken supercharger at home to measure from.
Sent from my LT26i using Xparent Skyblue Tapatalk 2
15-02-2020, 04:35 AM #95
buzzard2011
15-02-2020, 05:00 AM
#96
the easy part is the measurements of the bolt holes,the not so easy part is getting the angles for the supporting legs,that bolt to the engine block and so forth,even with measurements you will still need to figure these angles out by fixing and adapting,until you've got it right.
im in the process of making another cradle,but its a slow process,
ill post some pics when its done,but dont hold yer breath.
on another note i still cant find the original pulley the tte kit used,i adapted a merc one,which is 138mm but others say one from the supra fits?
its like finding the holy grail haha.:presents2:
buzzard2011
15-02-2020, 05:00 AM #96
daveo
15-02-2020, 05:30 AM
#97
ha ha the holy grail !!!! Smile let us know when ya find it.
yea there is no problem measuring the hole positions. ive an eaton there to measure up. as above its all about getting the angles rite. even having another cradle longside you , your still going to have issues with the angles all working intogether nicely.
in thinking a block bracket machined out of a big lump of ally rather than the bar cradle type.or then again using some item ally and making up a frame that way. might have a look into the weekend and see how it goes for me.
daveo
15-02-2020, 05:30 AM #97
16-02-2020, 03:27 AM
#98
I'm actually still in the process of acquiring a genuine TTE cradle.
But my opinion, having looked into making a cradle, is that trying to make an exact copy of the TTE one is a waste of time and that you are better off just making your own design.
As long as the holes for the engine and charger are correct, what you put between them is irrelevant.
16-02-2020, 03:27 AM #98
16-02-2020, 04:04 AM
#99
this is true but using the design i thought it would have been easier as getting it lined up so you dont shred belts would be half the mission
16-02-2020, 04:04 AM #99
daveo
17-02-2020, 01:09 AM
i dont think you would shred belts if you had a block bracket with slightly elongated slots for adjustment. if your paranoyed about making a cradle and belts shredding id be asking someone else to make it far ya Smile its very easy to run a straight edge along the front of thr 2 pulleys to ensure squareness. i think people are makingt a bigger issue out of making this bracket than there is to it !!Smile if you have an eye at all in your head and a vernier and the use of a cnc mill i think there wouldnt be too much to it.
daveo
17-02-2020, 01:09 AM #100
 4 Guest(s)
 4 Guest(s)
Views 489
29-08-2021, 09:59 AM
Views 479
29-08-2020, 07:09 AM
Views 207
28-12-2019, 02:56 PM
Last Post by Ste176
Replies 32
Views 1,570
08-09-2019, 10:48 AM
Last Post by sprinter2012
Views 378
01-09-2019, 02:49 AM
Views 960
20-08-2019, 12:01 PM
Last Post by Lance79
Views 713
05-08-2019, 12:42 PM
Last Post by mattlaw
Views 690
02-08-2019, 12:35 AM
Views 528
21-04-2019, 01:19 PM
Views 638
04-04-2019, 03:08 AM
Last Post by is300_dino
