Pages (139): Previous 117 18 19 20 21139 Next
07-12-2016, 02:35 AM
Wow that is low! Almost as low as the cc pump on my car... I'd have thought you'll be fine TBH, having things low around the wheel areas is alright because they go up and down with the suspension so your chances of grazing on speedbumps etc are low.
Edit: Amongst other things, if you made them flat would you have exhaust clearance issues?
07-12-2016, 02:35 AM #181
07-12-2016, 02:36 AM
Glad you sorted it mate, they do look quite low on your motor? :w00t:
07-12-2016, 02:36 AM #182
07-12-2016, 02:37 AM
The new bars look also quite heavy compare to OEM.Are they from aluminium or steel? Are they much heavier?
07-12-2016, 02:37 AM #183
07-12-2016, 02:44 AM
toxo Edit: Amongst other things, if you made them flat would you have exhaust clearance issues?
More than likely, it prob a good idea keeping them low as then they get battered not the car i suppose
07-12-2016, 02:44 AM #184
dimis The new bars look also quite heavy compare to OEM.Are they from aluminium or steel? Are they much heavier?
there steel from what i can tell. and yeah they are a fair bit heavier
07-12-2016, 02:44 AM #185
07-12-2016, 03:36 AM
Nice work, love the cruise control thing that's an awesome mod!
07-12-2016, 03:36 AM #186
07-12-2016, 03:37 AM
quite impressed with it myself, just need to rub the old letters off and get some new stickers on there
07-12-2016, 03:37 AM #187
07-12-2016, 08:43 AM
Sparkystav there steel from what i can tell. and yeah they are a fair bit heavier
Just put a magnet on it then you'll know :tongue_smilie:
07-12-2016, 08:43 AM #188
07-12-2016, 09:13 AM
Moley Just put a magnet on it then you'll know :tongue_smilie:
With the magnet you can only distinguish it is stainless steel or not. You cannot know if it is aluminum, only from the weight!Big Grin
07-12-2016, 09:13 AM #189
07-12-2016, 09:35 AM
dimis With the magnet you can only distinguish it is stainless steel or not. You cannot know if it is aluminum, only from the weight!Big Grin
sorry but you are wrong. stainless the magnet just sticks ever so slightly and with aluminium it dose not stick atoll. Try it with a aluninium drinks can and you'll see :biggrin::biggrin:
07-12-2016, 09:35 AM #190
 3 Guest(s)
 3 Guest(s)
Views 357
22-02-2024, 02:07 PM
