JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Help With a Small Project
05-02-2020, 05:45 PM
Ok I can't find it so must be on the hdd at work Smile
05-02-2020, 05:45 PM #11
05-02-2020, 05:46 PM
Thinking about it jay Russell did a walkthrough in fitting sill plates that uses the same wire if memmory serves ....
05-02-2020, 05:46 PM #12
Dinho
05-02-2020, 06:21 PM
I will have a go 2moro morning, I'll just need help taking the ignition barrel apart and i think i should be home free
Dinho
05-02-2020, 06:21 PM #13
05-02-2020, 06:59 PM
You don't need to take the barrel apart, just the speedo cover off
2 screws above the speedo, one at the bottom below the steering wheel, and the cover comes off.
You can then easily get to and tap off the ignition ring.
05-02-2020, 06:59 PM #14
jomo
05-02-2020, 08:23 PM
Plus getting the feed off the ign barrel the leds will fade out and not just turn off which looks way cooler imo.
jomo
05-02-2020, 08:23 PM #15
Dinho
05-02-2020, 10:02 PM
Thanks for the info Stav, im on that in the morning, will take a few pics if it turns out alright.
Dinho
05-02-2020, 10:02 PM #16
Dinho
07-02-2020, 08:12 AM
Ok I completed my small project, but whilst doing it ive somehow created another problem. The air bag light has come on now, im not sure why, I had been checking some fuses but if there is an air bag fuse would taking it out and putting it back trigger the light to come on?
How do I get it off?
Dinho
07-02-2020, 08:12 AM #17
lex2oos
07-02-2020, 12:10 PM
google around how to reset airbag light on lexus (same as toyota)
this is what I found on a quickie...
STEP 1: Turn the ignition on for approximately 20 seconds, but do not start the engine.
STEP 2: Stick a wire or paper clip in the Tc & E1 pinholes of the DLC2.
STEP 3: If the light blinks continuosly or code 22 (two fast blinks, a pause, then two more fast blinks), then you can probably manually cancel the warning light. If it is any other code, you need to trouble shoot it and fix the problem.
STEP 4: To clear the code connect two wires to Tc and AB of the DLC2.
STEP 5: Turn the ignition to ACC or ON and wait approximately 6 seconds.
STEP 6: Start with the Tc terminal and apply a wire to body ground alternately to Tc and AB twice each in cycles of 0.5 - 1.0 seconds.
STEP 7: Finally keep Tc to ground. If the clearing is done properly, then the airbag light will blink in 50 msec incriments continously. If it did not, then you didn't ground the Tc and AB properly. Repeat the process. The procedure may take between 3 to 15 attempts to work.
lex2oos
07-02-2020, 12:10 PM #18
07-02-2020, 04:19 PM
Hmm not sure about that guide. Isn't that for obd 1 cars? Rather than the IS that's obd2.
07-02-2020, 04:19 PM #19
lex2oos
07-02-2020, 06:10 PM
http://bahamutcars.free.fr/workshop/IS_9...i_0287.pdf
2nd page
I have not tried it, but reading other posts, seems to be working for lot of toyotas and lexus.
lex2oos
07-02-2020, 06:10 PM #20
2nd page
Replies 140
Views 11,813
05-03-2021, 02:51 PM
Last Post by Rolex
Views 1,066
04-08-2020, 06:31 PM
Last Post by mattlaw
Replies 35
Views 3,857
04-07-2019, 02:59 PM
Last Post by D.F!ANT
Views 1,817
21-04-2019, 05:32 PM
Last Post by mplavery
Replies 51
Views 4,115
20-11-2018, 07:20 PM
Replies 74
Views 5,369
03-08-2018, 03:11 AM
Views 1,034
05-04-2018, 04:43 PM
Views 1,274
25-10-2017, 06:51 AM
