JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Wideband Gauges
Wideband Gauges
Wideband Gauges
08-01-2021, 06:18 PM
Having a quick look at the manual it maybe possible to reprogram the range inthe software. If not you can use a voltage divider
08-01-2021, 06:18 PM #11
Jon
08-01-2021, 06:27 PM
ive downloaded the software and had a look, but I cant see anywhere to set it up, unless I have to be connected to the gauge!
Wheres the best place to get a voltage divider from, and will it work correctly. the AEM manual says 14.44 AFR is 3volts, divid by 5, = 0.6, is 0.6 roughly 14.4 on a narrowband?
Jon
08-01-2021, 06:27 PM #12
Jon
08-01-2021, 06:38 PM
or the other option is just to get an o2 simulator,
either make my own, if i can find the correct diagram, or order one from the states for $40 (about £25)
Jon
08-01-2021, 06:38 PM #13
08-01-2021, 07:10 PM
A voltage divider is just 2 resistors mate, google it
08-01-2021, 07:10 PM #14
Jon
08-01-2021, 07:31 PM
Sparkystav A voltage divider is just 2 resistors mate, google it
Cheers Stav,
Let me check if I have this right, using this diagram,
[Image: Resistive_divider.png]
and the calc on wikipedia
Vin = 5vdc
Vout = 1vdc
R1 = 4ohm
R2 = 1ohm
should work?
Jon
08-01-2021, 07:31 PM #15
Cheers Stav,
Vin = 5vdc
Vout = 1vdc
R1 = 4ohm
R2 = 1ohm
should work?
08-01-2021, 07:55 PM
Should work mate, but its doing it with available resister sizes (they don't do every resistance)
08-01-2021, 07:55 PM #16
08-01-2021, 07:58 PM
Also using high resistors is better apparently, so a 10k and 39k something like that
08-01-2021, 07:58 PM #17
Views 290
27-02-2022, 12:19 PM
Views 570
13-02-2021, 04:34 PM
Last Post by argyle dan
Views 765
15-06-2020, 04:10 PM
Last Post by S
