JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications how important is the ground when fitting gauges
S
15-06-2020, 01:11 PM
Hello all,
Can someone tell me how important the ground is when fitting gauges - specifically an AFR Gauge and a boost gauge.
I read somewhere that the ground you use for the AFR is very important, I was just going to use the ground from the stereo - is this ok? Or should I run a separate ground to a grounding point?
Thanks
Stix
S
15-06-2020, 01:11 PM #1
Hello all,
Thanks
Stix
15-06-2020, 01:16 PM
Run a good ground it's important to ensure the correct voltage.
I use the bolts that hold the stereo in.
15-06-2020, 01:16 PM #2
15-06-2020, 03:24 PM
Witchanic wouldn't fit gauges on the ground ... When you drive away you will either run them over or leave them behind Smile
15-06-2020, 03:24 PM #3
S
Thanks mate!
One other question - does it matter how many times I T the vacuum pipe?
It's just the one I have ran from the TB is T'd to the SSQV, the MAP Sensor and now the boost gauge!
S
15-06-2020, 03:24 PM #4
Thanks mate!
S
15-06-2020, 03:43 PM
purplewitch Witchanic wouldn't fit gauges on the ground ... When you drive away you will either run them over or leave them behind Smile
^PROTIP - Listen close people!
S
15-06-2020, 03:43 PM #5
15-06-2020, 03:51 PM
No mate it doesn't matter. Just more places to leak though so make sure theyre tight.
I have an old plenum for sale if you want that?
It's basically a machined tube, with threaded fittings. You connect the boost off take to the end, the. Tap off from the other ports.
15-06-2020, 03:51 PM #6
S
15-06-2020, 04:10 PM
Great!
Your alright for now stav, I'm just going to cable tie all of the connections but if they do leak ill give you a shout! Thanks though!
Edited 27-07-2012, 07:56 PM by S.
S
15-06-2020, 04:10 PM #7
Great!
Views 175
27-02-2022, 12:19 PM
Views 789
08-01-2021, 07:58 PM
Replies 33
Views 2,136
25-05-2020, 05:11 PM
Last Post by S
Replies 36
Views 2,136
15-10-2019, 05:38 AM
Last Post by Bandit
Replies 23
Views 1,817
12-06-2019, 11:52 AM
Last Post by lookatmybiceps
Replies 74
Views 4,325
05-04-2019, 01:59 PM
Last Post by bounty`
