JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza jap nav!
jap nav!
jap nav!
30-11-2019, 06:51 AM
6 cylinders or 4? Erm... Does it say BEAMS on it in red letters or silver?
30-11-2019, 06:51 AM #11
petay
30-11-2019, 07:02 AM
nothing as posh as a beams one. 6 cylinders with, as my mate said 'Enough room there for a massive turbo!!'
petay
30-11-2019, 07:02 AM #12
30-11-2019, 07:04 AM
AS200 then. Technically exactly the same as an IS200. Both types of Altezza (RS200 is the 4 pot one) use BEAMS engines, as does the IS200 - it just means the head & ECU were designed by Yamaha. Most Toyota engines are!
Edited 10-01-2013, 04:38 PM by toxo.
30-11-2019, 07:04 AM #13
petay
30-11-2019, 07:08 AM
its odd they chose a 4 cylinder one to tweak, I would have thought the 6 cylinders would have more scope for squeezing extra horses out.
petay
30-11-2019, 07:08 AM #14
S
30-11-2019, 07:32 AM
You could try putting a European satnav disc in the "ecu"?
It's worth a try?
S
30-11-2019, 07:32 AM #15
It's worth a try?
petay
30-11-2019, 07:41 AM
yeah that was my first thought. There is a site that offers new disks but you have to first choose which generation nav you have, then the code on the current CD.
with not having a nav remote I cant get to the menu to determine which generation I have. A bit of googling says 2002 plus IS200's come with generation 2 navigation, but aquiring a generation 2 disk is proving tricky. have tried a generation 1 disk but that gives this error [Image: Wy-DIQnt3Mu2WrRJ8v9U2cE6ROi2NESRBcqlkPQl...directlink]
with google translate I can get '11 dragon earth click' which might not be the actual message Tongue It is different to the no disk image so im assuming that generation 1 disks dont work!!
petay
30-11-2019, 07:41 AM #16
30-11-2019, 08:10 AM
Gen 1 were CDs I think gen 2 were DVD based?
30-11-2019, 08:10 AM #17
30-11-2019, 08:19 AM
petay its odd they chose a 4 cylinder one to tweak, I would have thought the 6 cylinders would have more scope for squeezing extra horses out.
if it had a 1j instead of a friggin 1gfe that would be correct. Instead we got the spares bin from the late 80s.
30-11-2019, 08:19 AM #18
petay
30-11-2019, 08:20 AM
The disk that is currently in it is a CD-Rom, it could be possible that its a CD only drive and my mystery message is saying 'cannot read disk'
petay
30-11-2019, 08:20 AM #19
S
30-11-2019, 08:25 AM
You could try replacing the whole sat nav ECU for an EU one?
I'm just thinking out loud mind so I don't know if it would work!
S
30-11-2019, 08:25 AM #20
 4 Guest(s)
 4 Guest(s)
