JapCarForum Cars, Cars, Cars! General Car Maintenance only getting hot air
john wan
12-03-2021, 09:48 PM
Hi mate if part of the heating part of the dash is broken let me know before you buy anything ive got most of it left over from when my heater stop working sure we could come to an agreementSmile
john wan
12-03-2021, 09:48 PM #11
13-03-2021, 01:08 AM
lex2oos if there is a problem with inside temperature sensor (if it is disconnected) HVAC only works in two ways - it will blow hot air unless temperature is set to maximum cold, then it will blow cold air...
Could you tell me where that sensor is located.
So I can see if it's still Ok
13-03-2021, 01:08 AM #12
13-03-2021, 04:30 AM
It's to the left below the steering wheel
13-03-2021, 04:30 AM #13
13-03-2021, 09:13 AM
I would need more info . Don't know what I'm looking for
13-03-2021, 09:13 AM #14
reganlives
13-03-2021, 09:26 AM
I've got a similar problem but its with the left side of the car only blowing cold air
reganlives
13-03-2021, 09:26 AM #15
lex2oos
13-03-2021, 10:09 PM
Moley I would need more info . Don't know what I'm looking for
cant find any pictures of it, but you will see it after taking off the panel that stands between steering wheel and pedals. there are 3 screws holding it and couple of clips. after taking it off youll see a white plastic tube and a wire connected to the sensor.
lex2oos
13-03-2021, 10:09 PM #16
lex2oos
13-03-2021, 10:15 PM
reganlives I've got a similar problem but its with the left side of the car only blowing cold air
what do you mean with cold air? you are getting only cold air no matter what the temperature setting is, or you are getting colder air than right side?
Whit colder I mean temperature difference - you can get warm air out of both right and left, but left side is not so hot as right.
is200 did not come with dual zone climat control, so if you have ONLY cold air on one side and other is normal i would say something inside climate control unit is seriously bad. if your left side is getting colder air than right side then you have clogged heater core, which is pretty common i think.
lex2oos
13-03-2021, 10:15 PM #17
john wan
14-03-2021, 11:16 PM
Right as ive got this kickin about thought id up load some pickys might help so this is the main part behind the dash
[Image: 20140425_170628_zpsgd0ochsw.jpg]
[Image: 20140425_170612_zpsq8vj69os.jpg]
[Image: 20140425_170554_zpsm1633w5u.jpg]
[Image: 20140425_170600_zpsgnun9bwy.jpg]
Edited 26-04-2014, 08:55 AM by john wan.
john wan
14-03-2021, 11:16 PM #18
reganlives
15-03-2021, 12:59 AM
lex2oos what do you mean with cold air? you are getting only cold air no matter what the temperature setting is, or you are getting colder air than right side?
Basically I can't get hot air out any of the left side of the car mate. When I set it to the highest temp I notice a slight temp change on the left but there's a substantial difference in temp. Going to try flushing the system soon in case there's a blockage in the matrix
reganlives
15-03-2021, 12:59 AM #19
john wan
15-03-2021, 01:37 AM
Ah mine did that then went cold on all sides then the heater matrix started to leak check the pipes in drivers foot well
john wan
15-03-2021, 01:37 AM #20
