JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza just read about some boot strut for the lex
russelllinn
18-10-2016, 10:52 AM
Mine pops up on it's own? Do they not all do that, there are tension wires inside that make it do that?
russelllinn
18-10-2016, 10:52 AM #11
18-10-2016, 11:28 AM
Marsdendean I think mines broke as the above post. Ill have to have a look to see if i can some how fix it,
I've heard of some that have snapped in the past, so it is likely that's what's happened. Might have to get some new ones (or used ones) or just go down the strut route.
Have to admit mine are so weak now a gentle push doesn't always make it go up, and if you push too hard it bounces and comes back and hits you on the head! Might have to get some new springs, or go for the struts too.
18-10-2016, 11:28 AM #12
18-10-2016, 11:42 AM
i'll have my strut sometime tomorrow(think their is 6 scrappage cars at my work) and poss fit it tomorrow night and the cost...............£zeroConfusedmoke::thumbup:
18-10-2016, 11:42 AM #13
19-10-2016, 01:07 AM
russelllinn Mine pops up on it's own? Do they not all do that, there are tension wires inside that make it do that?
It's supposed to pop open fully on its own, but after a while they often stop doing so. Probably if you have a spoiler on the boot it doesn't help either.
19-10-2016, 01:07 AM #14
19-10-2016, 01:21 PM
well made one looks amazing doesn't fire the boot through the back window the down side.....it puts the boot out of alighn!!!!(took a strut off a nissan micra)will need to look for one thats not so strong(a AX one or one with a fiberglass/light weight boot)then i'll be sorted.:thumbup:
19-10-2016, 01:21 PM #15
19-10-2016, 02:11 PM
ormi well made one looks amazing doesn't fire the boot through the back window the down side.....it puts the boot out of alighn!!!!(took a strut off a nissan micra)will need to look for one thats not so strong(a AX one or one with a fiberglass/light weight boot)then i'll be sorted.:thumbup:
Is there no way to bleed it?
on the ones you buy from RS you can bleed some of the gas out.
19-10-2016, 02:11 PM #16
20-10-2016, 12:50 AM
Sparkystav Is there no way to bleed it?
Think it needs to be a variable force strut to do that, and doubt that manufacturers would fit them on a car?
Marsdendean Mine used to fire nearly throu the back window, and i think thats why it has broke some of the boot bracket.
Don't you have a boot spoiler though? I've had two 05 cars as courtesy cars in the past and they lifted quite smoothly.
20-10-2016, 12:50 AM #17
Views 354
27-03-2022, 11:16 PM
Views 184
01-07-2020, 12:35 AM
Views 190
23-03-2020, 11:52 AM
Views 373
28-08-2018, 02:48 PM
Views 365
04-08-2018, 11:45 AM
Last Post by ormi
Views 519
23-05-2018, 10:09 AM
Last Post by Dinho
Views 707
01-04-2018, 10:32 AM
Last Post by jasons
Views 1,046
13-01-2018, 04:17 PM
Last Post by hawk77ojc
Replies 43
Views 1,811
21-06-2017, 02:34 AM
Last Post by Fozzy
Views 324
17-03-2017, 10:36 AM
Last Post by James S
