JapCarForum Cars, Cars, Cars! General Car Maintenance car storage
car storage
car storage
17-11-2016, 08:03 AM
Bandit i have one of these ones i never been to sure they work that well, having said that i not had a flat battery since purchasing it :laugh:
17-11-2016, 08:03 AM #11
17-11-2016, 08:30 AM
Well they do work but I have one you plug into the wall socket, there would not be much sunlight in a dark garage with the lights switched off:laugh:. When I come home and if the battery is flat I charge it up during the day and switch it off at night
17-11-2016, 08:30 AM #12
spikes
17-11-2016, 09:21 AM
cheers guys,the car was left for five weeks with a new battery and as expected was flat i have a normal charger put that on for 5mins and started the car, just wanted to know the best way to leave it. :biggrin: only prob if battery disconected is no alarm unless there is some sort of back up for itHuh
spikes
17-11-2016, 09:21 AM #13
17-11-2016, 11:29 AM
Moley Well they do work but I have one you plug into the wall socket, there would not be much sunlight in a dark garage with the lights switched off:laugh:. When I come home and if the battery is flat I charge it up during the day and switch it off at night
Easy way to use one mate if you have a garage like yourself, would be to extend the cables, and mount the solar panel on the outside of the garage Big Grin :thumbup1:
Or you could mount the unit outside, and wire it into a 2 pin plug socket inside the garage, then make a lead with the battery connectors on one end and a 2 pin plug on the other, all you do then is plug it into the socket on the wall when you want to use it :thumbup: Confusedmoke:
17-11-2016, 11:29 AM #14
17-11-2016, 12:37 PM
That would be a good idea if it run off rain and snow not the sun:laugh:
17-11-2016, 12:37 PM #15
 7 Guest(s)
 7 Guest(s)
