JapCarForum General Discussions The JCF Lounge Supercharger?
Supercharger?
Supercharger?
22-12-2016, 12:02 PM
that should be a sticky^^^^
22-12-2016, 12:02 PM #11
James S
22-12-2016, 12:46 PM
I saw the same supercharger on ebay yesterday.
What does the supercharger connect too??
Obivously driven by the crank. So does that mean that it is not connected to the exhaust side of the engine??
How do the TTE superchargers get the compressed air into the engine. :confused1:
James S
22-12-2016, 12:46 PM #12
James S
22-12-2016, 12:52 PM
Does the outlet from the supercharger, come out the pipe at the top, down through the intercooler then back up and straight into the standard air intake?
:blink:
Lots of questions I know, just trying to get my head round how it works!
James S
22-12-2016, 12:52 PM #13
:blink:
22-12-2016, 01:30 PM
James S I saw the same supercharger on ebay yesterday.
Correct its not connected to the exhaust side.
a turbo spins by using the gas coming out of the exhaust side of the engine. this is connected to a shaft that spins another fan sucking air in and compressing it.
an supercharger spins by a belt connected to the engine.
the chargers get the air to the engine the same way turbos do. a spinning fan/blades compress the air and then threw pipe and the intercooler to the inlet.
22-12-2016, 01:30 PM #14
rob
22-12-2016, 11:08 PM
Bandit Few of the prices here from TTE?
4; AM 27929 valve, assy, bypass, cable operated 302,07 €
WOW thats a real rip off, I can buy exactly the same part for about $40
rob
22-12-2016, 11:08 PM #15
Andy-R.
23-12-2016, 01:48 AM
So this'd fit an IS:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...%26otn%3D1
[Image: Lf9Nl.jpg]
Andy-R.
23-12-2016, 01:48 AM #16
[Image: Lf9Nl.jpg]
23-12-2016, 03:55 AM
Only with all the other bits to go with it - like the cradle.
23-12-2016, 03:55 AM #17
rob
23-12-2016, 05:51 AM
wouldnt touch it - suspect its leaking oil so needs a stripdown. but its the correct type
rob
23-12-2016, 05:51 AM #18
23-12-2016, 06:13 AM
Here another that looks a lot cleaner
http://cgi.ebay.co.uk/EATON-M62-SUPERCHA...23051ca524
23-12-2016, 06:13 AM #19
23-12-2016, 06:15 AM
I'd think about all the costs very carefully before going and buying a supercharger, even a second-hand one. There are still a *lot* of other bits that you need, and the cradle will be particularly important, to make sure the charger sits in the right place and runs smoothly off the crankshaft.
A lot of the bits you need will be the same as for a turbo, so you might want to consider a turbo upgrade as an alternative, which will likely have a lot more headroom. The biggest difference is likely to be needing a turbo manifold, but that's a similar issue to needing a cradle for the charger (i.e. finding one or making one).
23-12-2016, 06:15 AM #20
Views 312
04-06-2020, 05:29 AM
Last Post by reganlives
Views 837
27-01-2017, 09:55 AM
Last Post by Bandit
