JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Modifying The Autoleads Facia For Is200 & Is300, Walkthru with Pics by DJ Wozza..
10-01-2017, 11:20 AM
or do like me and fit heated seats in the back and put a 3rd switch for the rear in the middle and then move the trc/snow button next to the light washer button
10-01-2017, 11:20 AM #11
10-01-2017, 11:43 AM
not a probs mate just giving you the credit because helped me a lot.
10-01-2017, 11:43 AM #12
10-01-2017, 12:27 PM
Marsdendean Or move your snow button next to the handbrake like mine Smile
jay_russell or do like me and fit heated seats in the back and put a 3rd switch for the rear in the middle and then move the trc/snow button next to the light washer button
2tongues You have the devils transmission though:Shooting:
Or just create a fully custom one in the tiny pocket under the arm rest like me
10-01-2017, 12:27 PM #13
10-01-2017, 12:30 PM
pics stav???
10-01-2017, 12:30 PM #14
pics stav???
13-01-2017, 10:02 AM
Seen this somewhere before :laugh::laugh::laugh:
13-01-2017, 10:02 AM #15
13-01-2017, 10:17 AM
DJ Wozza I did think I had posted it funnily enough, but thought to myself if Bandit is posting it up I must be mistaken :laugh:
Someone asked for it mate, so thought i'd post it again :laugh: at least if they search now they will get 2 decent results :laugh::laugh:
13-01-2017, 10:17 AM #16
19-01-2017, 12:08 AM
Right so i started this yesterday and as woz says it certainly does take time, Ive glued the pocket bracket in, filled it and sanded it down.....by then it was past 11pm and thought that will do for tonight!!.....there are still a few minor imperfections, would it be worth putting some primer on at this stage and then sanding again, or get it perfect before applying the primer and sanding.......
19-01-2017, 12:08 AM #17
19-01-2017, 12:10 AM
Yes, it can be worth spraying it then taking a look, because the primer will let you better see how the surface is looking. Keep going till you're 100% happy with it, you don't want to end up installing it and then spottng some imperfections you wish you'd sanded more !
19-01-2017, 12:10 AM #18
19-01-2017, 12:20 AM
steviewevie Yes, it can be worth spraying it then taking a look, because the primer will let you better see how the surface is looking. Keep going till you're 100% happy with it, you don't want to end up installing it and then spottng some imperfections you wish you'd sanded more !
For sure mate, it just takes a while though hey:cursing:LOL!! Theres a few bits thats im going to sand down further tonight, followed by a good wash as i want to get the primer on tonight.....need it ready for the weekend.....is it worth putting more than 1 coat of primer, or should i not bother and add more coats of the top coat?
19-01-2017, 12:20 AM #19
iLLzLex
19-01-2017, 01:10 AM
DJ Wozza Some more info to add (that I had posted elsewhere)
If you are fitting the Head Unit directly to the unit rather than using a cage, the inner trim piece above can be glued and sanded/shaped and you end up with this
[Image: RedsFacia1.jpg]
[Image: RedsFacia2.jpg]
Close up the line can be seen, this is only because enough time wasn't taken to ensure it was perfectly joined and flattened off. This is quite time consuming,
but it can be achieved so it looks like one complete housing piece rather than two seperate pieces joined. The extra time is well worth it :thumbup:
Just remember this modification takes a lot of time and patience, if you don't have both, it won't result in you being happy with the result.
Good Luck !!
Beyonce fan? :lol:
iLLzLex
19-01-2017, 01:10 AM #20
Good Luck !!
Beyonce fan? :lol:
Views 662
30-09-2022, 11:42 AM
Replies 88
Views 19,705
26-01-2020, 06:18 AM
Last Post by iceman
Views 2,448
30-09-2019, 12:19 PM
Last Post by timmurray85
Views 716
28-09-2019, 08:22 AM
Views 423
17-09-2019, 11:52 AM
Views 750
12-07-2019, 10:36 PM
Views 797
03-07-2019, 01:12 PM
Last Post by lexuslloyd
