wanted - is200 crank sensor
The method for installing a new throttle body is detailed here and here. Technical diagrams here.
You will see that the only "programming" is setting up the throttle position sensor.
You can also see the procedure for checking it in the first place, here.
jayson2323 thanks rev hightower, is that physically set so nothing to do with electronic programming?:thumbup:
