JapCarForum Car Manufacturers Toyota steering prob
steering prob
steering prob
15-01-2017, 02:45 PM
water can pass the boots on the pistons causing them too rust.....
remove the wheel, on the caliper you will see 2 14mm remove these remove the caliper now you will see the slides they go through the rubber boots....
15-01-2017, 02:45 PM #11
15-01-2017, 11:37 PM
The slides are the pins that the caliper moves on.
15-01-2017, 11:37 PM #12
TM
16-01-2017, 08:57 AM
Blushsounds like your abs is kicking in
try to remove the front hubs,to check the ring
if the gets rust or mud etc the sensor read incorrect
most likely need a clean.but dont damage the sensor
if it pulling to the n/s ;then the o/s is were your problem is:thumbup:
hope this helps,:Shooting:Confusedcared:
TM
16-01-2017, 08:57 AM #13
paramedic
16-01-2017, 12:12 PM
thanks to all the guys who gave me the info for the braking/steering prob with my rav4,i will take up the info and get back to you.
thanks again .
paramedic
16-01-2017, 12:12 PM #14
thanks again .
paramedic
16-01-2017, 12:16 PM
one more thing whats the better out of the two :
ferodo or mintex brake pads.
paramedic
16-01-2017, 12:16 PM #15
16-01-2017, 02:29 PM
Reverend HighTower Blushsounds like your abs is kicking in
removing the hubs you wont see a thing.......the pick up is on the bearing
16-01-2017, 02:29 PM #16
icemahn
16-01-2017, 02:48 PM
I had the same problem with my MR2 before. I checked the brakes and found the pads were worn out on one side than the other. I changed it to find a sticky piston. The piston slides out but does not retract fully thereby creating unbalanced braking. I overhauled the entire caliper with piston out and the problem disappeared.
Hope this helps.Wink
Mazda CX7. 2.3 Turbo MPS. Corksport air intake. Turbo Smart dual port.
icemahn
16-01-2017, 02:48 PM #17
TM
16-01-2017, 11:34 PM
ormi removing the hubs you wont see a thing.......the pick up is on the bearing
:confusedConfusedo what does the hub run on.....:confused:
TM
16-01-2017, 11:34 PM #18
17-01-2017, 11:35 AM
you said remove the hubs and check the ring for mud/**** and what i said is it doesn't have a ring and the pick up for the abs is on the bearing.so no point in removing the hubs.
17-01-2017, 11:35 AM #19
TM
18-01-2017, 01:56 AM
ormi you said remove the hubs and check the ring for mud/**** and what i said is it doesn't have a ring and the pick up for the abs is on the bearing.so no point in removing the hubs.
but thats what he has to check:Chair:
TM
18-01-2017, 01:56 AM #20
 7 Guest(s)
 7 Guest(s)
