JapCarForum Cars, Cars, Cars! General Car Maintenance K&N Filter Cleaning
K&N Filter Cleaning
K&N Filter Cleaning
Bobby
09-03-2017, 05:57 AM
Mabozza Ritchie i haven't cleaned my K&N since it was fitted 2.5 years ago :blushing:
What you like, have you cleaned your car yet :wink:
Cheers
Bobby
Shy boys don't get sweeties.
Bobby
09-03-2017, 05:57 AM #11
Cheers
Bobby
Ally
09-03-2017, 06:50 AM
Bobby What you like, have you cleaned your car yet :wink:
Awright Bobby, how you doing? I've not cleaned my car since JAE :laugh:
JDM black headlights, rear fog light conversion, JDM size number plates, JDM rear number plate garnish, JDM dash tray, wind deflectors, TRD body kit, white TRD gearknob, TTE lowering springs, TTE ARB's, K&N air filter, stainless steel A/C rings, stainless clock cover, radiator cooling panel, LED side light bulbs, blue reversing bulbs, fan washer jets, clear side repeaters, PIAA silicone wipers, Alpine IDA-X200 headunit, 17 x 8 et40 OZ Ultraleggera with 225/45/17 Toyo Proxes T-1R
Ally
09-03-2017, 06:50 AM #12
09-03-2017, 07:10 AM
:laugh: Got the kit, thats about as far as ive got:blushing:......going away for a few days later in the week so plan to do it when i get back along with oil/filter change.....will let you know how i get on!
09-03-2017, 07:10 AM #13
09-03-2017, 10:26 AM
:laugh::laugh:
09-03-2017, 10:26 AM #14
:laugh::laugh:
11-04-2017, 04:38 AM
Bit of an update, serviced the car yesterday so gave the filter a clean....boy did it need it.....didnt take no before pics but heres a bucket with the water that flowed through the filter....
[Image: IMG_0513.jpg]
[Image: IMG_0512.jpg]
After applying the oil & refitting the filter i took it for a drive and it seemed a bit sluggish on idle, infact worse and then it cut out....gave it a good thrashing and it was idling much better...excuse the blown bulb:tongue_smilie:
[Image: IMG_0514.jpg]
......at this point i was quite sure i had over oiled the filter:blushing:, took it out and there was oil in the air box.......:Fish: so took it out cleaned the airbox washed the filter again.....Oiled again this morning (correct amount for IS filter is 1.25oz (i had used about 2 yesterday:ChairSmile....and it should look like this:thumbup1:
[Image: IMG_0515.jpg]
so its idling much better now, i just need to keep an eye on whether it cuts out when coming to a stop as it was before
Edited 23-05-2010, 03:32 PM by SHAHZ.
11-04-2017, 04:38 AM #15
11-04-2017, 05:56 AM
Just been out in it again and it seems to be running really well, so far so good......heres some pics of where its idling now with the properly oiled filter....where it should be:thumbup1:
In neutral
[Image: IMG_0516.jpg]
In drive
[Image: IMG_0517.jpg]
11-04-2017, 05:56 AM #16
In neutral
In drive
John G
11-04-2017, 06:32 AM
this whole resetting the ecu malarky, how do you know if youv done it right, i removed both fusses for 5 mins but how do you know thats worked?
[Image: MySig.jpg]
John G
11-04-2017, 06:32 AM #17
[Image: MySig.jpg]
11-04-2017, 08:22 AM
Looks good SHAHZ. What state was that water in though ? Confusedhock:
Resetting the ECU John, you only need to leave the fuses out for a few seconds really, 30 seconds is recommended. So 5 minutes will be more than enough and it will definitely have reset if you took out the right fuses (ECTS and EFI).
11-04-2017, 08:22 AM #18
11-04-2017, 09:33 PM
Dean that were a Auto should be around 700 to 800.
Otherwise as it goes in to gear it will cut out.
11-04-2017, 09:33 PM #19
11-04-2017, 10:10 PM
Marsdendean ^^^ How much is the kit steve?
The K&N cleaning kit (cleaning solution plus oil) is around a tenner. Opie Oils have it here, or you will find it on eBay (search for "K&N cleaning").
11-04-2017, 10:10 PM #20
Views 1,035
08-11-2021, 10:57 AM
Last Post by Morango
Views 1,429
02-04-2021, 11:15 AM
Last Post by 1374lee
Views 1,037
17-02-2021, 08:43 AM
Views 876
19-07-2019, 05:18 AM
Replies 24
Views 1,893
24-09-2018, 09:43 AM
Last Post by reco2k
