JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza help high oil pressure
TM
15-04-2017, 09:58 AM
:confused1Confusedounds like a pressure release valve is stuck
think u can buy the service kit for the pump
hope u get it sorted mate
TM
15-04-2017, 09:58 AM #11
TM
15-04-2017, 10:02 AM
:confused1:i remember on the land rovers , this used to happen on steep climbs ,and u had to tap on the release cover on the oil pump,and this worked all the time
TM
15-04-2017, 10:02 AM #12
15-04-2017, 10:25 AM
steviewevie I don't think just changing the oil is going to fix that
Actually, I partially take that back, thinking about this some more.
I guess changing the oil and filter is probably worth a try, in case some gunk is blocking the oil flow (or the filter is faulty ?) and that comes out with an oil change.
Just thinking out loud here, but I wonder if they used something to flush the engine, and something has got stuck somewhere and not come out ?
15-04-2017, 10:25 AM #13
Chri5
15-04-2017, 11:01 AM
Can't you take it back to them and explain the situation???
Chri5
15-04-2017, 11:01 AM #14
fluff
15-04-2017, 11:24 AM
When I picked my LS up from Hatfield, it was almost 10mm above the max so it wouldn't suprise me that they have over filled it with oil. Stick some lovely Castrol Edge fully synthetic 0W-30 in it. That's what i've been using in mine and can highly recomend it.
fluff
15-04-2017, 11:24 AM #15
fluff
15-04-2017, 11:29 AM
Another way round it is to supply your own oil so they defanitly can't use too much. Do they still use engine flush at Lexus dealers? I know Nissan use it in the Micra when I have it serviced.
fluff
15-04-2017, 11:29 AM #16
15-04-2017, 12:54 PM
well it looks like this is going to be an expensive month after all.
jim really 0w30? how come?
chris i would love to but cant afford there prices now.
steve so pulling the filter should remove any ****
terry how easy is the pump sevice and getting to the valves?
15-04-2017, 12:54 PM #17
15-04-2017, 10:30 PM
I'm just guessing mate, just in case maybe the filter is faulty or something ? An OEM oil filter only costs a few quid.
15-04-2017, 10:30 PM #18
fluff
16-04-2017, 02:50 AM
That's what the Castrol website recomended. It certainly makes the engine feel looser.
fluff
16-04-2017, 02:50 AM #19
Views 278
22-02-2020, 03:31 AM
Views 321
27-05-2016, 03:40 AM
Last Post by reganlives
