Brakes Failed?
Brakes Failed?
Chri5 Well flaring is easy.
Just don't forget to put the nuts on
personally tho I would be taking it back.
fixed !
couldnt undo the whole pipe, as the nut damaged in the engine bay, so i put a joint in and replaced the split in the copper pipe, very easy to do, and brakes perfectly fine,
tested them under stress to the point the car skidded, did that a few times and no loss of compression of the brake pedal
once again chuffed did it with direction from my bro, and now got the tools to do it as well
whats next?
P.S if you want to learn alot about repairing cars, buy an astra !
Marsdendean ^^ did you not ask the garage then?
