JapCarForum General Discussions The JCF Lounge Upgrading brakes today
iLLzLex
02-01-2017, 02:21 AM
Wooo, got my appoitment with the mechanic in 30 mins to get my discs swapped to EBC turbo groove with yellow stuff pads (all 4)...will let you know of the difference and how the drilled/grooved disk looks through the wheels...IM VERY EXCITE!!!
iLLzLex
02-01-2017, 02:21 AM #1
02-01-2017, 02:23 AM
Nice upgrade mate. why are you fitting yellow pads? These are only for race tracks. Better to fit Green or Red. Yellow is too much. I am very satisfied with the EBC disks and Green pads.
02-01-2017, 02:23 AM #2
iLLzLex
02-01-2017, 02:25 AM
dimis Nice upgrade mate. why are you fitting yellow pads? These are only for race tracks. Better to fit Green or Red. Yellow is too much. I am very satisfied with the EBC disks and Green pads.
hi, erm you know what, to be honest with you, when i was on the website it said yellow stuff are the best but it also said that they can be used anywhere from street to track so i thought id get them...ill see how they perform
iLLzLex
02-01-2017, 02:25 AM #3
02-01-2017, 02:27 AM
ok mate, but it will take more time to warm up and they might be a bit noisy!
02-01-2017, 02:27 AM #4
iLLzLex
02-01-2017, 02:38 AM
Sad hope not, leaving now...will report when i get back!
iLLzLex
02-01-2017, 02:38 AM #5
john 99t-reg sport
02-01-2017, 04:23 AM
sorry mate, i bought these from crn products for 399.99 and also using do luck brake hoses extra £60 from different seller, the standard set up is better, these new ones take ages to warm up (ie have to brake really hard 5-10 times before they work decent 90mph to 30mph etc, and work 10% less well than standard from cold ie day to day driving. they also seem to have a thin layer of rust if you leave it in the wet for 24 hrs but soon comes off though after a 2 min journey. i feel they were a waste of money for the expense but do look good when shiney and clean.
john 99t-reg sport
02-01-2017, 04:23 AM #6
02-01-2017, 04:29 AM
This was my worry for the yellows pads if your not up to temp then there not going to be as good.
However if your driving the car hard then they will be so much better but watch that licence
02-01-2017, 04:29 AM #7
James S
02-01-2017, 04:44 AM
I use red stuff pads and turbo groove discs on mine, and they are great. Even from cold.
Think I might go for Green ones next time though, see if they produe less dust!
James S
02-01-2017, 04:44 AM #8
iLLzLex
02-01-2017, 05:35 AM
O.K... let me dissolve the myth right now...I nearly went through the WINDSCREEN when I tested them straight after leaving the garage...seem A LOT better than standard...one question - they are making a rubbing noise when I'm driving up to 30mph - is this the pads bedding in?
iLLzLex
02-01-2017, 05:35 AM #9
02-01-2017, 06:41 AM
sounds like a caliper isn't seated properly
02-01-2017, 06:41 AM #10
Views 375
01-04-2020, 11:45 PM
Last Post by carmel
Views 94
15-01-2020, 01:22 AM
Last Post by wullie_trd
Views 268
08-05-2019, 11:17 AM
Last Post by is300_dino
Replies 29
Views 1,293
08-07-2018, 06:45 AM
Last Post by Mikey
Views 384
27-06-2018, 06:02 AM
Last Post by Carpediem
Views 282
11-03-2018, 12:08 PM
Last Post by bash6673
Views 830
15-02-2018, 01:51 AM
Views 338
13-01-2018, 05:46 PM
Replies 29
Views 1,164
24-07-2017, 03:02 AM
