JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Day time running lights
14-07-2018, 04:46 PM
In my brothers starlet, he had a set of day runners, and there was a little 6 pin block, where the windscreen wipers, and other things connected to each other, there was a wire which came on with the ignition, it may be no help to you in a Lexus, but what my dad used in fitting those.
14-07-2018, 04:46 PM #11
14-07-2018, 05:59 PM
Gord she wants them to come on with the ignition! :Chair:
Not turn off at night or turn off during the day, just, wants them to come on with the ignition! :thumbup:
but she wants day runners, if you painted it black it'd make the headlights on all the time like a volvo!
but then if you messed with the wiring to attach them to the day runners you'd lose the auto headlights
14-07-2018, 05:59 PM #12
Phil01
14-07-2018, 06:58 PM
why was my reply deleted????????
Phil01
14-07-2018, 06:58 PM #13
14-07-2018, 06:59 PM
What reply dad?
14-07-2018, 06:59 PM #14
What reply dad?
Phil01
14-07-2018, 07:03 PM
In reply to your auto headlight sensor, all i was saying was a LDR works opposite to the auto light sensor, obviously some mod did not like it!
Phil01
14-07-2018, 07:03 PM #15
Phil01
14-07-2018, 07:08 PM
Sparkystav Your best bet as Rabster says is using a switched live in the ECU,
use the owners manual online to identify one.
No point using an LDR if she wants them on in the day
An LDR switches ON the circuit in daylight NOT switches OFF
http://www.technologystudent.com/elec1/ldr1.htm
Phil01
14-07-2018, 07:08 PM #16
Phil01
14-07-2018, 07:30 PM
Sparkystav why would you want to?>
Because that is why they are called DAYTIME running lights.
DTR lights have no directional lens so would cause dazzle in low ambient light levels,
Have you noticed on Audi/Mecedes that during daytime the intensity is great, but at night the light level is greatly reduced.
Phil01
14-07-2018, 07:30 PM #17
15-07-2018, 08:00 AM
But Dean, they dim the DRL, so you can see the indicator better.
15-07-2018, 08:00 AM #18
jomo
15-07-2018, 09:37 PM
Ok, so i fitted a set to mine today and wired then up to the sidelights with a 500ma quick blow fuse to keep everything safe.
Will have a look at hers tomorrow and look at connecting them up to a live feed from the ecu so they come one with the ign, as she hardly drives at night and doesn't want the rear lights on as well!
So fitting them to the auto on lights is defeating the object....
jomo
15-07-2018, 09:37 PM #19
Carpediem
16-07-2018, 07:06 AM
PICTURES
If you search for DRL on the spanish audi forums theres an awesome thread on them
guy does it properly and cracks the headlight casing open and fits them there
Carpediem
16-07-2018, 07:06 AM #20
PICTURES
Replies 32
Views 2,679
08-11-2020, 12:39 PM
Last Post by Predator
Views 994
14-10-2019, 03:39 PM
Last Post by jomo
Views 813
29-07-2018, 10:04 AM
Last Post by Duv
Views 1,536
30-01-2018, 04:59 PM
Last Post by abactus
Views 2,095
12-07-2017, 08:03 AM
Last Post by N2KHL
