central locking fault
Rabster where is best to inspect it your place or mine i have various bits here for testing here
How do you lock/unlock it!! by the remote buttons or by using key in door lock.
What happens when you lock/unlock it by the manual rocker switch in the car??
@ rabster, andy if you are going up to kevs, give me a shout and I will come up with you mate, I'm off work all day tomorrow (monday).
Phil01 How do you lock/unlock it!! by the remote buttons or by using key in door lock.
if anyone can help.
my tel no is ********* if not in have got answer phone.
many thanks
i am now starting to feel ill worrying about the car.
cheers kev.
sounds like the battery has a low voltage and its just under the threshold for low battery if its got the same system as mine the idea is to open the doors to enable the user get in and start the car before a deep discharge if u check the voltage it will be arond the 11 volt mark which is just enough to start that particular model.
