JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Workshop - Submit Your Tip! Tail lights/boot fog lights LED instalation on standard housing
hawk77ojc
15-01-2018, 01:33 PM
jomo Its got Queensland sunshine state on the bottom of his plate, so dont think he's local!
Yes, you got that right, I am not "local" but I would definetly do it for someone here. It is not that hard to do it believe me. It requires alot of patience and if you follow the steps you should be fine mate.
hawk77ojc
15-01-2018, 01:33 PM #11
18-05-2018, 03:37 AM
Good job Hawk only thing is I dont think these give off enough light for brakes but I Could well be wrong
18-05-2018, 03:37 AM #12
hawk77ojc
18-05-2018, 03:57 AM
Lexusboy Good job Hawk only thing is I dont think these give off enough light for brakes but I Could well be wrong
Hi,
well they actually do give quite a lot of light for arking lights. i wouldnt use them for brake unless I get another smaller circle inside. Funny thing though, I am working on another set with much much brighter LED's. i think they will be much brighter than the normal SMD lights. I will use the same type of rings I used for the headlights.
i will post some pics soon.
They look totally different then anything I have done and seen.
Cheers,
Mercer
hawk77ojc
18-05-2018, 03:57 AM #13
Hi,
Cheers,
Mercer
 8 Guest(s)
 8 Guest(s)
