JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension steering rack bushes
08-02-2018, 03:35 AM
Not only that but the new one will need pressing in too, won't it?
08-02-2018, 03:35 AM #11
aaronabbott
08-02-2018, 04:57 AM
i was just wondering as my bushes are that knackered they will just fall out,
and as that the steering rack is right at the bottom so i can get at it from under the car if i undo the bolts that attach it ,it will give me enough room to get the old ones out and press the new ones in
aaronabbott
08-02-2018, 04:57 AM #12
aaronabbott
10-02-2018, 01:52 PM
..UPDATE..
had my steering rack bushes replaced today and the knocking noise is still there, i heard somewhere the steering rack has a pretensioner,is this true?
and how do you adjust it?
aaronabbott
10-02-2018, 01:52 PM #13
..UPDATE..
10-02-2018, 01:58 PM
If it's like the MR2 one, there's an enormous hex nut you ahve to undo to partially disassemble the steering rack. Only do it if you're sure it's the pretension that's at fault. I'm sure ormi will be along to fill you in Smile
10-02-2018, 01:58 PM #14
Phil01
10-02-2018, 02:11 PM
also check your rack end bushes, also known as inner tie rods or in the trade the drumsticks
Phil01
10-02-2018, 02:11 PM #15
10-02-2018, 02:12 PM
Yeah, you've got a lot of other things to check out first before you go messing with preload!
10-02-2018, 02:12 PM #16
10-02-2018, 02:14 PM
wondered about the bushes as ive never heard of them going as they dont really get much use.....what all have you had checked??or replaced??
10-02-2018, 02:14 PM #17
aaronabbott
10-02-2018, 02:23 PM
things that have been changed-
track rod ends
lower ball joints
aaronabbott
10-02-2018, 02:23 PM #18
track rod ends
lower ball joints
10-02-2018, 02:28 PM
The whole track rod end, or just the outer?
10-02-2018, 02:28 PM #19
aaronabbott
outer
aaronabbott
10-02-2018, 02:28 PM #20
outer
Views 653
14-10-2019, 10:02 AM
Views 458
25-08-2018, 07:29 AM
Views 1,033
15-07-2018, 11:06 PM
Views 880
14-07-2018, 06:47 AM
Views 695
23-07-2016, 12:36 PM
Last Post by Asi
Views 618
16-07-2016, 04:21 AM
Last Post by aaronabbott
