JapCarForum General Discussions The JCF Lounge Burnt my headlamp trying to JDM them :((
12-03-2018, 08:40 AM
Don't worry about it... I only do the very very simple stuff on my car, anything that required more than a ratchet set to do, I've had someone else (OK, it was ormi Smile) do for me (and even some of that stuff too :lolSmile
12-03-2018, 08:40 AM #11
D6NGR..
12-03-2018, 09:34 AM
DaveEdin Don't worry about it... I only do the very very simple stuff on my car, anything that required more than a ratchet set to do, I've had someone else (OK, it was ormi Smile) do for me (and even some of that stuff too :lolSmile
that makes me fel better know lol dave thats its not just me whosnot that much handy well not with my lecky
D6NGR..
12-03-2018, 09:34 AM #12
12-03-2018, 11:40 AM
Nope, not just you...
My sig lists a bunch of mods, but the actual work is broken down like this..
Done by me:
Steering Wheel Badge, S/S Dials, S/S Clock Surround, S/S A/C dials, 6K HIDs, Custom S/S Gearknob, KW-AVX810 Double DIN Stereo, Leather Arm Rest, Fan Washers, Crystal Side Repeaters, Detangoed JDM'd headlights(fitted only, they were painted etc by Demon, I just bought them)
Done by Ormi
TRD Yellow ARBs, Drilled/Grooved Discs, Mintex Pads, Moley Bars, TTE Front Bumper, TRD Side & Rear Skirts, IK20 Plugs & other servicing etc
So all the difficult stuff I shout for help on Smile
12-03-2018, 11:40 AM #13
Done by me:
Done by Ormi
D6NGR..
12-03-2018, 04:56 PM
arghhh seriously don't really want to attempt it again Sad
D6NGR..
12-03-2018, 04:56 PM #14
rob
12-03-2018, 09:46 PM
i have spil about 4 sets so far, i can safeely safe 130 degrees C for 10 mins works wekk, its enough to soften the sealant but not hot enough so it just falls apart.
rob
12-03-2018, 09:46 PM #15
13-03-2018, 12:24 AM
My car's got an LED high level brakelight and I melted that good and proper trying to split it apart to replace some failed LEDs. You are not alone.
When I did my foglights I used a hairdryer!!
13-03-2018, 12:24 AM #16
D6NGR..
13-03-2018, 02:25 AM
rob i have spil about 4 sets so far, i can safeely safe 130 degrees C for 10 mins works wekk, its enough to soften the sealant but not hot enough so it just falls apart.
yeah but rob my oven doesn't have the degrees onit it just says it in numbers from 0-9 and its confusing not knowing what degrees its on??
D6NGR..
13-03-2018, 02:25 AM #17
karlp
13-03-2018, 02:29 AM
I would say its 25 degress incriments that means 9 is probaby 225 c so you would want 6 or 7 and keep checking it, or get a cheap thermometer?
karlp
13-03-2018, 02:29 AM #18
D6NGR..
13-03-2018, 02:53 AM
i'm going to have to do something know Karl i've got one more headlamp left :/ right once you split it and that and do what you have to do then what do you just put them back together and put them in the oven????
D6NGR..
13-03-2018, 02:53 AM #19
karlp
13-03-2018, 02:59 AM
yeh matey stick back in the oven for about 5-7mins on a low heat to soften up glue then push back together you can use sealent around the light also for extra protection if you wanted
karlp
13-03-2018, 02:59 AM #20
 4 Guest(s)
 4 Guest(s)
Views 442
23-09-2016, 03:16 AM
Last Post by Chris
