JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission current best place for spark plugs?
HollowPoint
13-08-2018, 04:22 AM
I use sparkplugs.co.uk, even with delivery they tend to be cheaper, they have vehicle guides on the website to get the right plug, be it iridium or platinum. As for brand, most jap cars use Denso or NGK from the factory, German cars tend to use Bosch or Champion from factory, I like to stick with the manufacturer for the most part, except I do run iridiums and not platinums.
HollowPoint
13-08-2018, 04:22 AM #11
rob
17-08-2018, 11:28 AM
FunkMasterJay Where from, Rob?
from ebay http://www.ebay.co.uk/itm/360320794502 arrived in 3 days, well packed.
rob
17-08-2018, 11:28 AM #12
rob
17-08-2018, 11:29 AM
sprinter2012 I heard the IS200 engines don't like Bosch plugs?
Most people use NGK or Denso I think.
I got 6 x Denso Iridium Power Spark Plug IK20 from Opie Oils for £45
someone has been telling you a load of balls
rob
17-08-2018, 11:29 AM #13
17-08-2018, 11:36 AM
rob someone has been telling you a load of balls
To quote your own words...
rob people should RTFM then you cant go wrong.
And if you do check the manual, you will see it says to use only Iridium tipped spark plugs, those Bosch ones are silver tipped...
Edited 28-09-2011, 09:17 PM by sprinter2012.
17-08-2018, 11:36 AM #14
rob
18-08-2018, 01:46 AM
sprinter2012 To quote your own words...
ooooooohh look at him :laugh: ......i see you are a bit sensitive or is the ***** chaffing a bit and making you irritable
iridium tipped is for extended service life and to keep within the timing of the service schedule, which you should of course know :wink:
i have no issue changing the plugs earlier so your example is null and void.
toddle along now dear chap
rob
18-08-2018, 01:46 AM #15
rob
18-08-2018, 01:48 AM
ok the system doesnt like ***** so you may replace it with vibrator instead.
rob
18-08-2018, 01:48 AM #16
18-08-2018, 01:54 AM
I reckons enough is enough of this ... Lets keep today friendly Smile
18-08-2018, 01:54 AM #17
18-08-2018, 02:04 AM
purplewitch I reckons enough is enough of this ... Lets keep today friendly Smile
Indeed, tis getting a bit silly. Happy faces on Smile
18-08-2018, 02:04 AM #18
18-08-2018, 02:14 AM
as said above enough is enough the question has been asked it seems the question has been answered no need for insults to be raised.....
18-08-2018, 02:14 AM #19
Views 316
05-06-2020, 07:02 AM
Last Post by Ji123
Views 427
03-07-2019, 05:15 AM
Last Post by reganlives
Views 666
25-01-2018, 12:24 PM
Last Post by Bonney
Views 522
10-01-2018, 04:05 PM
Last Post by hawk77ojc
