JapCarForum General Discussions The JCF Lounge Broken down!
Broken down!
Broken down!
03-08-2018, 02:50 AM
Confusedad: hope you can fix it before the weekend and you can get to the pod, hope you get home safe
03-08-2018, 02:50 AM #11
03-08-2018, 03:02 AM
My money's still on it being something basic. Knackered sensor, hole in a hose or at worst the precats. Big things don't tend to just let go and when they do they do it in a much more dramatic fashion than that!
03-08-2018, 03:02 AM #12
03-08-2018, 03:12 AM
Phil01 jim leading up to the breakdown and at the time what sort of speeds/loads/boost were you at mate, general idea of the loads on the engine??
Was travelling at about 75mph in 5th gear and just cruising like that for about 10+ miles. I'd be surprised if I was making boost, if I was it would only be 1-2psi. Had mrs and kids in car so no ragging it.
Funny thing is that for a while I had noticed the car was unusually smooth. Almost like I was coasting. It was only when I needed some power to overtake I could really tell something wasn't right!
03-08-2018, 03:12 AM #13
03-08-2018, 03:18 AM
toxo My money's still on it being something basic. Knackered sensor, hole in a hose or at worst the precats. Big things don't tend to just let go and when they do they do it in a much more dramatic fashion than that!
The grinding is what worries me. It's like the grinding kicks in when I try to apply power.
03-08-2018, 03:18 AM #14
speedfreek
Hope it's nothing serious mate, gutting when these things happen.
'99 Lexus IS200 SE Navigator
[/SIZE]
(Current project)
speedfreek
03-08-2018, 03:18 AM #15
[/SIZE]
(Current project)
03-08-2018, 04:43 AM
Ok so home now. Engine sounds 100% fine at idle and even when I free rev. However tge back end if the car is really quiet. Considering I've got a custom exhaust setup it's not burbling anywhere near as much as normal. Wtf???
03-08-2018, 04:43 AM #16
03-08-2018, 04:46 AM
Sounds like the Cat is the problem if of course you have one fitted:whistling: could it of broken down and your not getting the gases through the system
03-08-2018, 04:46 AM #17
03-08-2018, 04:51 AM
Could well be possible. I've checked all the pipes for damage or leaks and I can't see anything though. I would assume that a collapsed cat would cause the surrounding area to heat up red hot?
I really need a second opinion tho as I'm worried I might not be thinking straight.
03-08-2018, 04:51 AM #18
03-08-2018, 05:01 AM
Ok, exhaust is definitely not expelling as much gasses as normal. Also water/condensation is dripping from the join between the midpipe and back box.
03-08-2018, 05:01 AM #19
03-08-2018, 05:02 AM
what happened to your toyomoto headers?
03-08-2018, 05:02 AM #20
Views 715
02-10-2018, 04:37 AM
Last Post by Mr Reman
