playstation3 keeps disconnecting! help!
it maybe the channel the router is on. i have a bt router and if i have the xbox laptop and 2 phones all wireless it plays up on 1 or even 2 items.
its all about finding the best channel on the BT router and disconnecting it and turning it back on sets the router to find the best channel hence why it works when you unplug it.
this is the problem i have not sure if it helps but you never no
I had this exact same problem, unreliable connection, switch router on and off and it would be back all fine for a bit, then dropped connection again.
Thanks to some advice on here used wifi analyser on my phone and discovered that my neighbour was using exactly the same wifi channel as me - swapped it over and now my connection is bulletproof.
Well worth checking that out before buying any extra bits
