JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security ODB2 Bluetooth Adaptor
el_gencer
09-12-2018, 11:40 AM
Might give that a go tomorrow. Does the kiwi do the same ?
el_gencer
09-12-2018, 11:40 AM #11
09-12-2018, 03:13 PM
No flashing lights on my dash...
09-12-2018, 03:13 PM #12
Jon
10-12-2018, 01:49 PM
el_gencer The next issue i found was the ABS light flashes when the device is connected. After a bit of searching, it turns out it also does the same on MR2s. Might be a Toyota thing with the ELM327 ?
I have the same OBD2 Bluetooth adapter, and it doesn't cause my ABS light to flash, never has and I've had mine for about 12 months now. Maybe a difference in firmware?
The USB OBD2 reader which I have had for about 3 years is also the same.
Jon
10-12-2018, 01:49 PM #13
el_gencer
10-12-2018, 02:49 PM
It only flashes if i plug it in before starting the car. The key trick that Dark Samurai mentioned also stops it from flashing as does connecting it up after the car has been started.
I did some extra testing today again. I cleared the memory on my phone and the dials responded a little quicker. I then tried it on an SGS2 and the update was comparable to my SGS. Not instant, but certainly a lot less laggy. Maybe i'm expecting too much ? I'll get the kiwi plx eventually but for now this'll do.
el_gencer
10-12-2018, 02:49 PM #14
 3 Guest(s)
 3 Guest(s)
Views 1,195
04-11-2021, 01:49 PM
Views 654
20-02-2018, 12:54 AM
