The AMG modding begins....
jimxms Yeah, I found it hard to believe that it's actually larger in some dimensions than the LS430! It feels much smaller to drive other than when parking as it doesn't have any parking sensors
Talisker
I like your catch cans, they're very elegant. Where did you get them from?
Talisker
toxo Those fittings are WAY too small for a forced induction engine!!
toxo You should never ever reduce the size of PCV vents, they're that size for a reason. I know of people who've destroyed engines as a result of putting a 4mm catch can on an engine that was designed to run with a 12mm PCV. And that was on 4 pot FI engines...
jimxms Thats a 10mm ID to an 8mm ID. The picture makes it look a lot worse because the 10mm hose is stuff I had left over for carrying petrol/meth and has a massive OD in comparison.
jimxms I see where you're coming from as it needs to vent crankcase pressure, but if it's going to do anything IMO it'd just pop-off the parts of the hoses i've left unsecured?
toxo Either that or your dipstick, whichever is easiest to remove
