JapCarForum Car Manufacturers Lexus/Toyota problem...need help
problem...need help
problem...need help
196
30-03-2021, 11:53 AM
Surly the intercooler gets hot? When you drive that's what cools the air but if you stop no cold air which will then cause it to get hot. Maybe not linked to sc maybe coolant problem what's tempature reading? It says you blocked bypass? Maybe the blockage has moved? A few ideas anyway.
lexusdaydreaming
30-03-2021, 11:53 AM #21
daveo
02-04-2021, 08:42 AM
Sparkystav A kinked pipe won't help. Off boost it'll just suck in and stall the engine.
dont have any kinked pipes, not the problem
daveo
02-04-2021, 08:42 AM #22
daveo
02-04-2021, 09:32 AM
lexusdaydreaming Surly the intercooler gets hot? When you drive that's what cools the air but if you stop no cold air which will then cause it to get hot. Maybe not linked to sc maybe coolant problem what's tempature reading? It says you blocked bypass? Maybe the blockage has moved? A few ideas anyway.
nope front mounts are not supposed to get hot Smile i could fry an egg on mine. temperature reads normal and the blocked port is a cnc machined cap so that cant move Smile thanks for the ideas Smile
daveo
02-04-2021, 09:32 AM #23
daveo
02-04-2021, 09:33 AM
Lexuspat is it possibly if you had it off at some point the pipework leading in or out has got something in there.
clutching at straws
no definately not pat Smile
daveo
02-04-2021, 09:33 AM #24
clutching at straws
Lance79
07-04-2021, 10:46 AM
Just reading this now, I'm not sure as to what is causing the intake air temp to get so hot that it's making it stall.
By a method of deduction all I could advise is the only thing that is in the way between the cold air outside and the throttle body is the induction kit, compressor and intercooler. The only one of them with any moving parts is the compressor. Even heat soak from the engine wouldn't get the intercooler roasting hot so it must be friction related. That leaves the compressor as the main suspect.
Do the other lads have the upgraded pulley's on their chargers? My only thinking is that the higher speed of the compressor at idle speeds is generating a lot of heat that it is not supposed to do. Does the compressor get hot too?
Lance79
07-04-2021, 10:46 AM #25
daveo
22-04-2021, 12:37 PM
Lance79 Just reading this now, I'm not sure as to what is causing the intake air temp to get so hot that it's making it stall.
the other lads are running off the crank pulley as they do not have a tte cradle. yes my compressor does get hot. my compressor is activated using one of the heated seat buttons. car runs fine with sc turned off and idles away fine when activated but when you sink the shoe she dies down. i took the patrick black box out are put the wiring back to original and it is the same, it dies when you sink the boot. so the patrick black box doesnt seem to be doing anything for the car.
ran a direct power line to the fuel pump also over the weekend
when putting oil in the supercharger am i better take the supercharger out and stand it on its end and fill it to the top or am i best fill it the way it is fitted ??
anybody got any ideas????
daveo
22-04-2021, 12:37 PM #26
Lance79
25-04-2021, 01:27 AM
Black box is not working. You are getting a fuel cut due to the supercharger giving the map sensor readings out of the normal range for the engine.
Lance79
25-04-2021, 01:27 AM #27
daveo
25-04-2021, 07:12 AM
i w2as thinking that. as the exact same thing happens with the box and without the box. trying to get through to the lad that makes them but no reply.....does anybody have his email. ??
daveo
25-04-2021, 07:12 AM #28
rob
01-07-2021, 06:58 AM
daveo I mean that the front mount gets hot as in not cold but hot Smile
surely somebody on here has some idea whats up ?? Smile
I actually meant what you mean by mount.
rob
01-07-2021, 06:58 AM #29
daveo
01-07-2021, 07:14 AM
Rite there was a loose pipe in the fuel tank which seemed to be a lot of the problem. Now the problem is similar. The car will go flat to the mat for about 10 15 minutes and she starts to loose power and cut out again....im still lost and dont know whats up with her.
daveo
01-07-2021, 07:14 AM #30
 7 Guest(s)
 7 Guest(s)
Views 383
04-10-2023, 12:38 PM
Last Post by CrocodileHunter
Views 212
01-02-2021, 01:25 AM
