JapCarForum Cars, Cars, Cars! Wheels & Tyres Time to replace the Goodyear Eagle F1 assymetrics on the IS200
Pages (3): Previous 1 2 3
24-12-2016, 09:21 AM
I can't fault my Conti sport contacts.
24-12-2016, 09:21 AM #21
24-12-2016, 10:21 AM
Very happy with my Toyo Proxes T-1Rs.
24-12-2016, 10:21 AM #22
kam05
24-12-2016, 10:36 AM
I'd go with the usual suspects for the IS200- Eagle F1a's, Falken FK452, Toyo T1R's etc.
I decided to try some different tyres this time. I went for the Yokohama C drives (after using the Eagle F1a's)- can't fault the Yoko's so far (only done 800 miles on them so far).
kam05
24-12-2016, 10:36 AM #23
boost
24-12-2016, 11:23 AM
I have yoko parada spec2 on mine, I found them good in the dry but fairly useless in the wet and a nightmare in snow!
boost
24-12-2016, 11:23 AM #24
Anees
24-12-2016, 11:47 AM
Marsdendean Just to bump an old thread.
What tyres do people recommend apart from the Falkens?? Going to get to Tony for a geo check, as well as possibly getting the two falkens off the fronts if i have the money.
What do people recommend?
Verdestein Ultra Sessanta. I have had the falkens and they are good, but I think these are even better - especially in the wet. :thumbup1:
I am thinking of getting a set for the Evo too!
[Image: clubbanner.gif]
Anees
24-12-2016, 11:47 AM #25
25-12-2016, 04:36 AM
Anees Verdestein Ultra Sessanta. I have had the falkens and they are good, but I think these are even better - especially in the wet. :thumbup1:
How are they in the cold? I've pretty much concluded now that my problems with F1As are all temperature related. When the ambient was around 2C, it was like driving on glass, now we've moved up to 8C feels like a completely different car. I've still got grip problems but nowhere near as bad as they were.
Now if I'm right, as soon as the temp gets into double digits and higher my grip levels should be back to normal. I will keep an eye on it and let everyone know, but if that is the case they can't really be recommended for a climate like ours.
25-12-2016, 04:36 AM #26
25-12-2016, 06:13 AM
Remember the Toyo R1R is available now Wink Factory fit for the EVO X FQ400.
Or the excelent (so I've been told) Marangoni Mythos range
Personal opinion is that for the money the Falkens are unbeatable. They're quite a hard compound so not the quietest of tyre but this does make them last longer (which is a blessing when you have a power hungry RWD motor) and once worn in the grip is awesome. They're not without their faults of course but you get what you pay for. I don't use anything else on my car but I am considering trying out the Marangoni range shortly. :thumbup1:
Edited 05-02-2010, 03:50 PM by toxo.
25-12-2016, 06:13 AM #27
25-12-2016, 06:51 AM
have to say had the F1 GSD3's and found them too soft and slippery in wet/greasy conditions compared to the cheaper and harder wearing FK452's
25-12-2016, 06:51 AM #28
25-12-2016, 06:53 AM
Dan_Turism0 have to say had the F1 GSD3's and found them too soft and slippery in wet/greasy conditions compared to the cheaper and harder wearing FK452's
+1, 1st crash I had was in the wet on F1's (admittedly the older than GSD3 model) and they offered very little grip.
25-12-2016, 06:53 AM #29
25-12-2016, 07:10 AM
That's what they've clearly fixed with the asymmetrics, the grip in the wet is unbelievable, and I'm not exaggerating, they really are that good.
But it appears that somehow it has made them quite sensitive to temperature.
25-12-2016, 07:10 AM #30
 10 Guest(s)
 10 Guest(s)
Views 1,415
20-08-2021, 11:21 PM
Last Post by reganlives
Views 1,129
27-07-2021, 08:37 AM
Last Post by leesw20
Views 867
19-10-2020, 02:31 PM
Last Post by Chris0121
Views 703
20-06-2020, 11:01 AM
Last Post by James S
Views 1,428
29-06-2019, 10:52 PM
Last Post by Dinho
Views 953
28-04-2019, 10:39 AM
Last Post by jasons
Views 840
03-03-2019, 11:55 AM
Views 1,351
28-02-2019, 11:10 AM
Views 1,005
31-10-2018, 07:06 AM
Last Post by MrGash
