JapCarForum Cars, Cars, Cars! General Car Maintenance Dot 5.1 brake fluid
Dot 5.1 brake fluid
Dot 5.1 brake fluid
Pages (3): Previous 1 2 3
19-01-2017, 12:15 PM
you wanting toyota stuff?i'll check and see if the stuff that we have kicking about is 5.1 i'll post it up too you.
19-01-2017, 12:15 PM #21
19-01-2017, 12:25 PM
ormi you wanting toyota stuff?i'll check and see if the stuff that we have kicking about is 5.1 i'll post it up too you.
No rush mate , no point in posting it when I'll be down your way soon enough.
:thumbup::thumbup:
19-01-2017, 12:25 PM #22
:thumbup::thumbup:
19-01-2017, 01:28 PM
Its got a higher boiling point, so better for when you are giving your motor a bit of death
19-01-2017, 01:28 PM #23
19-01-2017, 11:11 PM
You're not really going to "feel" any difference with DOT 5.1 fluid. You do need to change brake fluid regularly though, it gradually absorbs moisture from the atmosphere over time, which stops it working so well. So if your brake fluid hasn't been changed for a while, putting some new stuff in (whatever type) and bleeding the brakes properly could help feel quite a lot.
When you're changing the fluid though, why not put something with a higher specification in there, if you're not using 5.1 already ?
19-01-2017, 11:11 PM #24
Views 1,021
11-04-2022, 07:55 AM
Views 1,118
01-10-2019, 11:51 AM
Views 649
24-07-2019, 07:48 AM
Last Post by uncle bob
Views 1,408
16-08-2018, 11:08 AM
Last Post by rsz325
Views 575
02-11-2017, 04:09 AM
Last Post by oilman
Views 589
01-10-2016, 09:42 AM
Last Post by icemahn
