JapCarForum Cars, Cars, Cars! General Car Maintenance K&N Filter Cleaning
K&N Filter Cleaning
K&N Filter Cleaning
11-04-2017, 10:11 PM
Marsdendean ^^^ How much is the kit steve?
My auto always stays at around 800 RPM for some reason!
What kit dean, the filter cleaning kit?? About £12 odd from eBay, as Ian says that's where it should be:thumbup1:
11-04-2017, 10:11 PM #21
11-04-2017, 11:46 PM
steviewevie Looks good SHAHZ. What state was that water in though ? Confusedhock:
Resetting the ECU John, you only need to leave the fuses out for a few seconds really, 30 seconds is recommended. So 5 minutes will be more than enough and it will definitely have reset if you took out the right fuses (ECTS and EFI).
And that wasnt even all of it alot of **** went straight down the drain!! Yep only need about 30 seconds, i pulled the fuses, put the filter back in and then put the fuses back in
steviewevie The K&N cleaning kit (cleaning solution plus oil) is around a tenner. Opie Oils have it here, or you will find it on eBay (search for "K&N cleaning").
Thats a good price and they got a 30% offer on at the moment, although i suppose you will need to add postage.....Dean, mine was well filthy, i didnt use any brush to loosen the dirt as it could damage the filter, heres what i did
1. Tapped it gently to remove any loose ****
2. Sprayed it with loads of cleaner & let it soak for 10 mins
3. Rinsed (ONLY POUR WATER ON THE CLEAN SIDE) with loads of water (not to much pressure, just a nice steady flow). Most of the **** will wash away but there was some bits left in there and tapping gently with the water flowing helped dislodge it!.
4. Let it dry completly....i left it in the sun for a few hours
5. Oil it - It really only needs 1 bead of oil on each pleat (on one side only)
6. Leave it for 10 mins and check the other side for white patches and oil accordingly.
7. Leave for an hour to set
8. Reinstall!
Edited 24-05-2010, 09:32 AM by SHAHZ.
11-04-2017, 11:46 PM #22
8. Reinstall!
TommyH
12-04-2017, 12:16 PM
Can you get a cleaning kit for a Toms Ram air filter ? Have looked everywhere and can't seem to find one.
Don't even know if you CAN clean them ?
TommyH
12-04-2017, 12:16 PM #23
12-04-2017, 10:35 PM
I didn't think the TOM's filters were ones you could clean. Though I could be wrong.
You thought I had what Dean, a TOM's filter or a cleaning kit ? I sold my K&N plus cleaning kit to another member on here. You do need the cleaning kit to give it a proper clean (though you could vacuum it to probably help a bit - but make sure you vacuum from the dirty side).
12-04-2017, 10:35 PM #24
TommyH
12-04-2017, 10:41 PM
steviewevie I didn't think the TOM's filters were ones you could clean. Though I could be wrong.
I dont think you can clean them Stevie because the Toms filter is made out of a foam type material but i'm not 100% sure.
TommyH
12-04-2017, 10:41 PM #25
25-08-2018, 02:09 PM
Car was beginning to cut out again so last weekend pulled the filter out to find it looking like this
[Image: Picture001-2.jpg]
[Image: IMG_1913.jpg]
Got the cleaning kit out and soon it looked normal again!
[Image: IMG_1926.jpg]
Ooooops the heat has made this cover crumble away!!
[Image: Picture003-2.jpg]
Major improvement, however still a slightly low idle, after reading Parthibans thread i think i might clean the throttle body!.........got a strange whine when accelerating since refitting it now though?!
25-08-2018, 02:09 PM #26
25-08-2018, 02:15 PM
Confusedhock: that cover is shocking never seen that happen before on a lex, a 20-30 year old car yeah, but not on a relatively new car
Edited 06-10-2011, 11:52 PM by is300_dino.
25-08-2018, 02:15 PM #27
25-08-2018, 02:46 PM
im sure i read somewhere it had happened to a someone else.....cant remember who though, i literally just touched it and it fell to pieces ..........you think it would be a little more resistant to the heat!
25-08-2018, 02:46 PM #28
25-08-2018, 02:49 PM
I wouldn't have thought that's down to heat personally, I'd be more inclined to think it just came out of a bad batch of plastic.
25-08-2018, 02:49 PM #29
25-08-2018, 11:42 PM
SHAHZ Major improvement, however still a slightly low idle, after reading Parthibans thread i think i might clean the throttle body!.........got a strange whine when accelerating since refitting it now though?!
Sounds like an earth fault, did you connect everything correctly and didnt trap any cables?
they do look like new when you refurb them
25-08-2018, 11:42 PM #30
 4 Guest(s)
 4 Guest(s)
Views 962
08-11-2021, 10:57 AM
Last Post by Morango
Views 1,319
02-04-2021, 11:15 AM
Last Post by 1374lee
Views 935
17-02-2021, 08:43 AM
Views 777
19-07-2019, 05:18 AM
Replies 24
Views 1,640
24-09-2018, 09:43 AM
Last Post by reco2k
