Morning peeps !!!!!!
Dark Samurai fcd only need a screwdriver dont they?
Phil01 I think she meant mm i.e millimetres
And no way will halfords or any DIY store will have that size, need a specialist tool shop, that's if that size is available.
Yeah I presume you mean to open up the ECU box to get to the FCD. Do you know what setting they put it on ? Does it not seem quite right ?
Just tried on mine, and a 10mm socket worked fine to open up the ECU box.
h11exx its on setting 8 thought of trying it on 10
Yeah be careful not to go too low. The lower the setting, the more the FCD is lying to the stock ECU, and the bigger the risk of going too lean.
On an off-topic note, anyone noticed the new forum feature on the forum index page (at the top) ?
