mmHg to psi or bar
mmHg to psi or bar
It is connected to the Boost (Apexi)- via a "T" that also feeds the EBC. The EBC displays BAR, press the right hand side button for 2 seconds after a run and it will display the max BAR for that run i.e. don't turn off the ignition after a run to check the boost setting. Press it for 4 seconds to reset it.
The Apexi has to be connected to boost otherwise the map won't adjust for boost fuelling.
