JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza programming new Key Fob help!!!!
wahidhussain
08-08-2017, 04:38 AM
captain Mine says exactly the same. Wahidhussain neither the immobilizer or the wireless lock works?
no mate they dont
wahid
wahidhussain
08-08-2017, 04:38 AM #21
no mate they dont
wahid
wahidhussain
08-08-2017, 09:28 AM
after checking the fob by opening it up
it takes a bigger battery (cr2016)
could this be the problem?
thanks
wahid
wahidhussain
08-08-2017, 09:28 AM #22
thanks
wahid
Andy-R.
08-08-2017, 10:04 AM
Try this matey: Stav sent me this when I first got my IS and it worked no prob.
Open Door.
Insert key into ignition then remove.
Using C/Locking switch on the door press Lock-Unlock 5 times.
Close then open door.
Lock-Unlock 5 times again.
Insert Key.
Turn from Off to On Twice.
Door Lock should respond.
Hold down Lock on they key and press Lock-Unlock 5 times again.
Release Lock button on key and press unlock.
[Image: Lf9Nl.jpg]
Andy-R.
08-08-2017, 10:04 AM #23
Open Door.
Insert Key.
[Image: Lf9Nl.jpg]
wahidhussain
08-08-2017, 10:13 AM
thanks andy r
try that tomorrow mate
am a bit tired know after trying to get it going
thanks
wahid
wahidhussain
08-08-2017, 10:13 AM #24
thanks andy r
thanks
wahid
wahidhussain
09-08-2017, 05:12 AM
Andy-R. Try this matey: Stav sent me this when I first got my IS and it worked no prob.
Open Door.
Insert Key.
hi
tryed that since 9am this morning mate
still no luck
thanks
wahid
wahidhussain
09-08-2017, 05:12 AM #25
Open Door.
Insert Key.
hi
still no luck
thanks
wahid
Fry-Up
09-08-2017, 05:36 AM
wahidhussain hi
still no luck
thanks
wahid
That does sound more like the method I tried and it did take a couple of attempts, ur main key is definitely a master key isn't it?
Fry-Up
09-08-2017, 05:36 AM #26
wahidhussain hi
still no luck
thanks
wahid
09-08-2017, 05:40 AM
I shall open my remote and give you the battery number when i get home later.
There are a number of batteries that fit into the Lexus range from
CR 1632
CR 1616
CR 1216
CR 2032
09-08-2017, 05:40 AM #27
CR 1632
CR 1616
CR 1216
CR 2032
kam05
09-08-2017, 06:20 AM
IS200 keys use CR1616 batteries.
kam05
09-08-2017, 06:20 AM #28
wahidhussain
09-08-2017, 07:22 AM
Fry-Up That does sound more like the method I tried and it did take a couple of attempts, ur main key is definitely a master key isn't it?
yes mate it is i got it with the car its the 3 button black key when i put it in the ignition the red light goes out
Lexusboy I shall open my remote and give you the battery number when i get home later.
CR 1632
CR 1616
CR 1216
CR 2032
its cr2016 and my master key battery is cr1616
thanks
wahid
wahidhussain
09-08-2017, 07:22 AM #29
CR 1632
CR 1616
CR 1216
CR 2032
thanks
wahid
Andy-R.
09-08-2017, 07:48 AM
Can you start the car with this key?
[Image: Lf9Nl.jpg]
Andy-R.
09-08-2017, 07:48 AM #30
[Image: Lf9Nl.jpg]
Views 559
29-03-2018, 06:50 AM
Last Post by jasons
Views 817
20-03-2018, 10:28 AM
Last Post by jasons
