JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Altezza Digital cluster project
04-11-2017, 01:27 PM
no mate both mine are in place. is 200 is a little different maybe. the other one i have here is the same. you cant remove it as there is a plate over it. and the plate is stuck down
04-11-2017, 01:27 PM #21
04-11-2017, 01:33 PM
jay_russell no mate both mine are in place. is 200 is a little different maybe. the other one i have here is the same. you cant remove it as there is a plate over it. and the plate is stuck down
The playe was screwed down, when you remove all the screws from the back it call came out including the coil.
04-11-2017, 01:33 PM #22
04-11-2017, 01:36 PM
yer i've not go in from the back but the front as thats the side i need to get to. maybe thats why it's still in there
04-11-2017, 01:36 PM #23
04-11-2017, 04:31 PM
the good news is the 3 center dials can be changed out for my ones i have now so there will be no problems with the oil pressure
04-11-2017, 04:31 PM #24
seecarr11
04-11-2017, 06:57 PM
you got a modellista cluster!!! those are rare like rocketships that are made out of wood!!
you're sitting on a gold mine right there
seecarr11
04-11-2017, 06:57 PM #25
05-11-2017, 12:59 AM
seecarr11 you got a modellista cluster!!! those are rare like rocketships that are made out of wood!!
Ay I know there a bit rare. Got it a fair bit cheaper than 500 as well. I know it doesn't have the digi bit but I love it.
05-11-2017, 12:59 AM #26
05-11-2017, 03:29 AM
well as you can see the oil pressure has gone and in it's place is the original power meter from my cluster. now yo go and see if it all works
[Image: SDC12052.jpg]
05-11-2017, 03:29 AM #27
05-11-2017, 03:53 AM
well i have a few lights on i should not have but not sure if thats a problem. the gauges in the middle dont all work but i might change out the small plus lead to mine as it have a few extra wires on it
[Image: SDC12053.jpg]
05-11-2017, 03:53 AM #28
05-11-2017, 03:58 AM
it was only the top small gauge that was not working. it's only the average kmh dial. not like i use it anyhow and that since i put the turbo in it's way off. just need to fix the rest of the displays leds on the bottom digital part.waiting for them to come
05-11-2017, 03:58 AM #29
05-11-2017, 04:20 AM
that top light on is your headlight adjuster one isnt it? you havent got them have you? only in the ones with HID'sfrom stock?
05-11-2017, 04:20 AM #30
Views 305
06-08-2022, 11:58 AM
Last Post by Brad92
Views 313
03-09-2021, 07:20 PM
Last Post by Ratchet
Views 233
14-03-2021, 03:16 AM
Last Post by TezzaJoe
Views 363
25-12-2020, 03:27 AM
Last Post by gsitlv
Replies 140
Views 8,127
05-03-2020, 09:02 AM
Last Post by Rolex
Views 269
05-12-2019, 02:23 AM
Last Post by Reject1970
Views 304
01-10-2019, 05:15 PM
Last Post by PETEHAMASAKI
Views 705
05-08-2019, 12:42 PM
Last Post by mattlaw
Views 598
21-07-2019, 10:57 AM
Last Post by Chris0121
Views 394
18-06-2019, 03:14 AM
Last Post by Kevpr
