JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza speedo cluster/clocks
gsitlv
23-06-2021, 09:39 PM
[Image: 000039181679_%23_2_%23_GSi.jpg?1375661606]
speedo/clocks from Limited Edition, so im wonder will it work on my 1999 lex?
gsitlv
23-06-2021, 09:39 PM #1
24-06-2021, 02:39 AM
Yes. Should fit straight in.
24-06-2021, 02:39 AM #2
gsitlv
24-06-2021, 08:23 AM
its works, but handbrake light stays on, and backlights not working Sad
gsitlv
24-06-2021, 08:23 AM #3
24-06-2021, 09:51 AM
hmm, need to check the wiring then looking at a wirin diagram, you may need to move the purple/white wire from pin 1 on the big plug to pin 10 instead
24-06-2021, 09:51 AM #4
24-06-2021, 11:41 AM
If that's not helpful info I don't know what is
24-06-2021, 11:41 AM #5
gsitlv
26-06-2021, 11:13 AM
i have plugs from both of cars, will have a look later what a difference
gsitlv
26-06-2021, 11:13 AM #6
gsitlv
24-12-2021, 02:11 PM
So find some time to play with speedo clocks, and ended up with abs light on and handbrake light on and no back lights. Can somebody send me a wiring diagram?? Thanks
I have is200 manual, but cant find diagram for speedo clocks Sad
gsitlv
24-12-2021, 02:11 PM #7
24-12-2021, 05:43 PM
If you have the manual it's called 'combination unit' instead of speedo no idea why lol
24-12-2021, 05:43 PM #8
gsitlv
25-12-2021, 08:05 AM
so thats 14pin connector
[Image: 000040429652_%23_2_%23_GSi.jpg?1391596576]
[Image: 000040429651_%23_2_%23_GSi.jpg?1391596574]
and 22pin connector
[Image: 000040429648_%23_2_%23_GSi.jpg?1391596557]
[Image: 000040429654_%23_2_%23_GSi.jpg?1391596581]
and end result ABS light and handbrake light on
[Image: 000040429655_%23_2_%23_GSi.jpg?1391596581]
and diagram
[Image: 000040429730_%23_2_%23_GSi.jpg?1391597270]
seems to be some different color wires...
gsitlv
25-12-2021, 08:05 AM #9
and 22pin connector
and diagram
gsitlv
25-12-2021, 09:15 AM
Is it possible to get wiring diagram from newer is200 for speedo?
gsitlv
25-12-2021, 09:15 AM #10
Views 850
19-08-2020, 09:50 AM
Last Post by S
Views 624
27-06-2020, 04:32 PM
Last Post by purplewitch
Views 1,118
26-04-2020, 01:54 AM
Views 645
22-03-2020, 05:23 AM
Last Post by reco2k
Views 31,235
31-01-2020, 08:34 AM
Views 957
11-04-2019, 04:49 AM
Last Post by IanS200
Views 2,151
31-03-2019, 04:20 PM
Last Post by AdamIS200
Replies 51
Views 4,198
20-11-2018, 07:20 PM
Views 849
03-08-2018, 07:37 AM
