JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza LCD Dash Clocks not working
28-06-2019, 02:34 AM
Hi all,
As the title says the lcd display has stopped working in the car,
It happened when I took the unit out. The rest of the unit works fine all the lighst work but the display is just empty (no read out)
I've fitted a second hand unit I got of stav and still nothing, lights fine all else works just not the display
Could there be an issue with the wiring/fuse
This is really annoying me and I can't seem to find out why it won't work
Help is really needed
Any ideas?????????????
28-06-2019, 02:34 AM #1
Hi all,
28-06-2019, 02:50 AM
You have gone and broken it mate Tongue
28-06-2019, 02:50 AM #2
28-06-2019, 03:18 AM
U have become as helpful as Sam, Andy :lol: :lol:
Any more help
28-06-2019, 03:18 AM #3
Any more help
28-06-2019, 03:19 AM
have you checked all the wires are seated properly in the back of the long wire connector at the back of it? I managed to knock one out of a different (but similar) connector behind the dash and it caused similar issues with the snow/traction control lights.
28-06-2019, 03:19 AM #4
there are 2 plugs on the unit. sure you put both in? only thing i can think you might have missed. but if you have not opened the clock up then cant see it being broken more a fuse or wire problem
28-06-2019, 03:19 AM #5
28-06-2019, 10:15 AM
I've had the unit open to change bulbs to SMDs but I've also tried a different unit and still not working
28-06-2019, 10:15 AM #6
28-06-2019, 10:43 AM
[COLOR="Plum"]oiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii !
I knew I was right .. burn it n buy a supra![/COLOR]
28-06-2019, 10:43 AM #7
Views 520
25-12-2020, 03:27 AM
Last Post by gsitlv
Views 828
05-08-2019, 12:42 PM
Last Post by mattlaw
Views 1,578
18-06-2019, 11:52 AM
Views 493
05-05-2019, 11:07 AM
Last Post by is200iain
Views 458
24-01-2019, 07:04 AM
Last Post by is300_dino
Views 802
28-09-2018, 11:44 AM
Views 659
20-05-2018, 11:24 PM
Replies 18
Views 1,181
04-05-2018, 02:09 AM
Last Post by bash6673
Views 1,363
31-03-2018, 10:31 AM
Last Post by AdamIS200
