JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza dash board light up like a xmas tree HELP!?
is200iain
01-05-2019, 10:28 AM
I got in my car this evening to go home and when a started my car the trc light, engine management light, abs light, oil light where all flashing. The engine was running ok so i drove home.
On the way home when moving just the engine management light was flashing aswell as the TRC light but when a applied the brakes all lights went out?
At junctions it felt like it wanted to stall and when i got home it idle very slow and then stop.
I'm thinking faulty coil pack? or something just f#@ked up?
Please help
Cheers
Iain
is200iain
01-05-2019, 10:28 AM #1
Please help
Cheers
Iain
01-05-2019, 10:53 AM
set the clock to june, not december lol.
best bet is to get the obd2 codes and go from there it honestly could be anything mate,
01-05-2019, 10:53 AM #2
is200iain
01-05-2019, 10:56 AM
thanks
i take it the diagonistic plus in engine bay is the obd2 socket
cheers
iain
is200iain
01-05-2019, 10:56 AM #3
thanks
cheers
iain
01-05-2019, 10:58 AM
As Dino has said - what you described was similar to when my alternator gave up, but battery's in IS200's don't last long at all without an alternator?
01-05-2019, 10:58 AM #4
01-05-2019, 11:13 AM
obd2 connects in the cabin near your right knee when your sitting in the drivers seat at the bottom of the dash cover theres a little sticky out block with a cover on a tether thats the obd2 port
01-05-2019, 11:13 AM #5
01-05-2019, 11:14 AM
There's an ODB2 socket in the driver's footwell, you need to pop off the cover to get at it...
01-05-2019, 11:14 AM #6
is200iain
01-05-2019, 11:58 AM
thanks everyone for info.
I have got someone coming to check fault code, hopefully it will shed some light
is200iain
01-05-2019, 11:58 AM #7
is200iain
05-05-2019, 11:07 AM
found out what problem was. It was the abs control unit had a fault. However it seems (touch wood) that its fixed its self. I will still make sure there are no corroded plugs.
Thanks again everyone for you help
is200iain
05-05-2019, 11:07 AM #8
Views 383
25-06-2021, 08:14 AM
Views 229
14-03-2021, 03:16 AM
Last Post by TezzaJoe
Views 398
14-01-2021, 04:38 AM
Last Post by lex2oos
Views 237
16-09-2020, 08:21 AM
Views 282
30-07-2020, 12:35 AM
Last Post by Dinho
Views 233
28-03-2020, 10:39 PM
Last Post by James S
Views 365
10-03-2020, 11:17 AM
Views 243
10-03-2020, 08:16 AM
Last Post by Colin G
Views 185
23-10-2019, 03:14 PM
Last Post by Jk 200sx
Views 373
10-10-2019, 05:16 PM
Last Post by MrGash
