JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza map light fitting?
map light fitting?
map light fitting?
25-06-2021, 05:04 AM
I've found 3 different answers on my.is so does anyone e know what fitting the front map light bulb is on the is300?
25-06-2021, 05:04 AM #1
25-06-2021, 05:19 AM
It should pop off and drop down on a hinge.
25-06-2021, 05:19 AM #2
25-06-2021, 05:27 AM
I'll have a look then. I need to order a new bulb, was going to do it while I'm still at work. Do you know what fitting it is?
25-06-2021, 05:27 AM #3
reganlives
25-06-2021, 06:01 AM
If its the same as the 200 then you need a flat blade screwdriver to pry it off. If I remember correctly there's 2 tabs which hold it in place. I replaced my standard bulb a couple of years back with an LED panel. Wont go back to standard bulbs again!
reganlives
25-06-2021, 06:01 AM #4
reganlives
Oh yeh, the tabs are between the plastic edging and the roof lining.
reganlives
25-06-2021, 06:01 AM #5
reganlives
25-06-2021, 06:04 AM
here you go dude...
http://my.is/forums/f115/how-change-map-...lb-344377/
What fitting is the bulb. That's all I want to know.
Edited 06-08-2014, 03:40 PM by el_bandido.
25-06-2021, 06:04 AM #7
reganlives
25-06-2021, 06:12 AM
Ahh, sorry mate, I'm not too sure what its called but from what I remember when I replaced mine with a led panel it had a 2 pin connector on it like a jumper on a computer motherboard. Dont remember if that then went into some kinda convertor though. I'll take a look when I get a chance if you want.
reganlives
25-06-2021, 06:12 AM #8
reganlives
25-06-2021, 06:15 AM
Right, I've had a look through my emails and purchase history and it was described as T10 BA9s....
Did a quick search on ebay and the best picture showing the fittings is as below...
http://www.ebay.co.uk/itm/T10-501-BA9S-D...3372cfc5d9
reganlives
25-06-2021, 06:15 AM #9
25-06-2021, 08:14 AM
Sweet, cheers.
25-06-2021, 08:14 AM #10
Sweet, cheers.
Views 297
14-03-2021, 03:16 AM
Last Post by TezzaJoe
Views 544
14-01-2021, 04:38 AM
Last Post by lex2oos
Views 306
16-09-2020, 08:21 AM
Views 371
30-07-2020, 12:35 AM
Last Post by Dinho
Views 233
01-07-2020, 04:42 AM
Views 323
28-03-2020, 10:39 PM
Last Post by James S
Views 510
10-03-2020, 11:17 AM
Views 299
10-03-2020, 08:16 AM
Last Post by Colin G
Views 238
23-10-2019, 03:14 PM
Last Post by Jk 200sx
Views 461
10-10-2019, 05:16 PM
Last Post by MrGash
