JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Speedo Cluster Help
Speedo Cluster Help
Speedo Cluster Help
reco2k
21-03-2019, 11:26 PM
Hi All,
I had my speedo out yesterday modifying the lights guides etc to make it look better but now all my needles are wrong. I have managed to sort the Rev and speedo out ok but the fuel guage, temp, mpg and voltage are all wrong. Is there a way to reset the clocks so they all read right again or a trick to putting the needles back in the right plasce? I have tried putting them on when it's all off and put them to their lowest possible point and tried putting them on when all the dials are connected and powered up but I cannot see to get them to sit right.
Many thanks all
Ross
reco2k
21-03-2019, 11:26 PM #1
Hi All,
Many thanks all
Ross
22-03-2019, 12:31 PM
Did you take the needles off the motors?
If so it will be hard to get them back in the right place.
temp can be sorted by letting the car warm up, then sticking the needle on in the middle position.
fuel can be done by filing the tank and then putting it at the top.
voltage, have the engine running and put it just under 14v
not sure about mpg though
22-03-2019, 12:31 PM #2
reco2k
22-03-2019, 01:16 PM
Yeah i did as i needed to get the dials themselves off to scrape off the light guidss on them. Got temp and voltage about right, speedo and revs are good now just got to sort the mpg, can somone take a pic of their mpg with the car running and stationary
Ross
reco2k
22-03-2019, 01:16 PM #3
Ross
22-03-2019, 01:22 PM
reco2k Yeah i did as i needed to get the dials themselves off to scrape off the light guidss on them. Got temp and voltage about right, speedo and revs are good now just got to sort the mpg, can somone take a pic of their mpg with the car running and stationary
Ross
Just looked up a pic from when I did my LED speedo, when the engine is running and the car is stationary the needle rests on the stopper.
But it's going to be VERY hard to get the mpg right from a picture because you'd have to have the throttle in exactly the same position, same speed, same angle of road surface etc.
22-03-2019, 01:22 PM #4
Ross
reco2k
22-03-2019, 01:24 PM
I thought the needle went to 0 when stationary... Will just have to mess with it til it looks right lol
Ross
reco2k
22-03-2019, 01:24 PM #5
Ross
22-03-2019, 01:27 PM
It does, the stopper is at 0. Well, it is on mine anyway. lol
22-03-2019, 01:27 PM #6
reco2k
22-03-2019, 11:34 PM
Hhmm i thought the stopper was over 80 will look at lunch
Ross
reco2k
22-03-2019, 11:34 PM #7
Ross
Views 509
25-12-2020, 03:27 AM
Last Post by gsitlv
Views 577
20-08-2019, 04:01 AM
Last Post by S
Views 832
26-04-2019, 08:05 PM
Views 854
31-01-2019, 02:46 AM
Views 620
10-04-2018, 11:00 PM
Last Post by IanS200
Replies 51
Views 3,099
20-11-2017, 01:31 PM
Views 641
03-08-2017, 01:48 AM
Views 261
31-07-2017, 09:16 AM
Last Post by M44TXY
Views 3,028
08-07-2017, 12:48 PM
Last Post by miziek
