JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Workshop - Submit Your Tip! Auto Window reset?
Auto Window reset?
Auto Window reset?
Phil01
04-02-2018, 02:16 PM
My window has done this since i have had it, but cant be naffed to investigate it.
Phil01
04-02-2018, 02:16 PM #21
karlp
20-02-2018, 07:26 AM
anybody found anything??
karlp
20-02-2018, 07:26 AM #22
karlp
05-03-2018, 09:14 AM
If I take my battery positive red off and leave overnight what effect will it have on my car to try and reset the auto window function as ormi said, obviously I'll lose radio stations etc anything else??
karlp
05-03-2018, 09:14 AM #23
05-03-2018, 09:38 AM
Clock will need reset I guess? Not sure about anything else though
05-03-2018, 09:38 AM #24
05-03-2018, 10:01 AM
Basically you'll loose every accessory with a memory function (radio, clock)
05-03-2018, 10:01 AM #25
karlp
05-03-2018, 10:31 AM
DaveEdin Clock will need reset I guess? Not sure about anything else though
How do you remove the red from battery?
karlp
05-03-2018, 10:31 AM #26
karlp
05-03-2018, 10:42 AM
cant believe I just asked that! Did ****** drop the pliers whilst against the live and hit the negative causing a some sparks!! Tried car and battery was fine, so locked car and now battery disconnected for the night, I heard some beeping when I disconnected the car is this normal? Also I presume no alarm tonight if no battery?
karlp
05-03-2018, 10:42 AM #27
karlp
05-03-2018, 12:04 PM
guys?
karlp
05-03-2018, 12:04 PM #28
guys?
karlp
05-03-2018, 10:28 PM
Okay reconnected battery this morning and still no joy with auto window, I did however try when I open the window then close it and hold it up then turn the ignition off the window automatically comes back down to halfway even though I'm still using the button??
karlp
05-03-2018, 10:28 PM #29
06-03-2018, 11:57 AM
Hmm does seem very odd mate, what about taking the door card off and manually winding it up? see if that resets it?
06-03-2018, 11:57 AM #30
Replies 29
Views 1,305
18-01-2023, 01:50 AM
Views 667
31-10-2017, 07:03 AM
Last Post by TommyH
Views 1,339
28-08-2017, 12:18 PM
