JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning anyone got there arches rolled and photos and widest wheels you can fit 18" ???
spikes
09-02-2018, 01:22 PM
jimxms its something like 50 iirc?
standard is200 5 spoke 7x17 et50
spikes
spikes
09-02-2018, 01:22 PM #21
spikes
danielson
09-02-2018, 01:25 PM
cheers spikes there real narrow i would of gussed 8j
danielson
09-02-2018, 01:25 PM #22
Sam B
13-02-2018, 02:29 AM
im running 18x9.5J ET10 rears 18x8 et30 front. just tugged,rolled and stretched.
[Image: DSC_0017-1-paper.jpg]
[Image: DSC_0042edit.jpg]
[Image: DSC_0038edit.jpg]
you can use this from my.is, it lets you work out where the wheel will sit.
Quote:Okay, here's the definitive guide to all the wheel offset and fitment questions. Here's the real way to figure out whether your wheels will fit!
EDIT: Thanks to NeoVB for this excellent link to help visualize wheel parameters - Wheel / tire size calculator / comparer - RIMS-N-TIRES
These limits are the practical extremes with good alignments. You can buy more fender room with camber or rolling or pulling. In front, you can buy more room with shorter overall tire diameter (<25") The closer you get to these limits, the more likely you will need to stretch a tire to fit the fender side. Drop does not determine what size wheels fit. Put too aggressive a wheel, and one day, you WILL bend your fender when you take the wrong turn with a good bump if you exceed these limits.
Measuring in mm from the face of the hub:
Front fender limit: +65mm
Comments:
| +65 | Stretch tire and/or roll fender. Need fender liner mod. Do not exceed tire diameter of 25"
| +55 | Fender liner mod if going for a wide or tall tire. Do no exceed tire diameter of 25.2"
Front inner suspension upright limit: -155mm
Comments:
Need spacer if this number is exceeded. If close, do not use lip weights on wheels
Rear fender limit: +68mm
Rear fender limit w/ shaved lip: +75
Comments:
Need to stretch tire to a certain degree if very close to these numbers
Rear inner suspension coil lmit: -183mm
Comments:
Several factors matter as you approach this limit. You may need to limit the amount of suspension travel. You may need to stretch tire. And you cannot run as aggressive camber. I've been able to actually scrub tire well before this limit (@ -175mm) with track cornering loads on the spring and inner forward tub.
Equations to figure out wheel lip placement relative to limits:
Outer lip: (Wheel Width * 25.4) / 2 - Wheel Offset
Inner lip: (Wheel Width * 25.4) / 2 + Wheel Offset
Note: Inner lip is related to backspacing but backspacing takes into consideration the wheel lip thickness, which is usually another 1/2" or 12.7mm.
Examples:
Front wheel size: 8.5" +45
Fender: 8.5 * 25.4 / 2 - 45 = 62.95 (< 65 - OK)
Suspension: 8.5 * 25.4 / 2 + 45 = 152.95 ( < 155 - OK)
Rear wheel size: 9.5" +55
Fender: 9.5 * 25.4 / 2 - 55 = 65.175 (< 68 - OK)
Suspension: 9.5 * 25.4 / 2 + 55 = 175.65 (< 190 - OK)
[Image: DWSIG2.jpg]
Sam B
13-02-2018, 02:29 AM #23
Comments:
Comments:
Comments:
Comments:
Examples:
[Image: DWSIG2.jpg]
danielson
13-02-2018, 04:09 AM
Big Grin:thumbup1: thats a sweet ride your car look great so 10j out of the window then .is your car a turbo ?
danielson
13-02-2018, 04:09 AM #24
Sam B
13-02-2018, 04:37 AM
you can get 10j under with a few mods and correct ET, mine only look that wide because the offset is so low.
thanks, it was turbo when that picture was taken now im in the process of swapping a 1jz into it. a project thread is on here.
[Image: DWSIG2.jpg]
Sam B
13-02-2018, 04:37 AM #25
[Image: DWSIG2.jpg]
danielson
13-02-2018, 08:38 AM
what et do you think ? whats the widest tyre that can go under the arches and i will have a look at you 1jz project bet you cant wait til shes done :thumbup:
danielson
13-02-2018, 08:38 AM #26
LEX11S
15-02-2018, 02:48 PM
Iam running 18x8.5 et30 all round all was needed was a 215 40 tyre and to tap the arch lip in on the back and ive gone right to the bottom of my coilovers, friend of mine had 18x 9.5 et30 on his with a 225 tyre
LEX11S
15-02-2018, 02:48 PM #27
15-02-2018, 11:49 PM
Just put on a set of 18x9 et43's in the rear with 225/40 tyres. Have got the arches rolled but am getting a slight rub on the wall of the tyre when going over bumps.
Not 100% sure if its coming from the inside of the arch or something else, but am going to put some masking tape on there and see if it rubs off.
15-02-2018, 11:49 PM #28
danielson
16-02-2018, 11:29 AM
LEX11S Iam running 18x8.5 et30 all round all was needed was a 215 40 tyre and to tap the arch lip in on the back and ive gone right to the bottom of my coilovers, friend of mine had 18x 9.5 et30 on his with a 225 tyre
does his rub ???
danielson
16-02-2018, 11:29 AM #29
does his rub ???
danielson
16-02-2018, 11:38 AM
all worked out want rears 18/10j or jj/et 10to13 now thats a strange size :lol:
danielson
16-02-2018, 11:38 AM #30
Views 239
11-07-2020, 10:33 PM
Last Post by Fry-Up
Replies 34
Views 1,585
27-07-2017, 07:33 AM
Last Post by reganlives
