JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning New wheels for the lexus
09-07-2020, 01:28 AM
i found a set of wheels with the following specifications:
18x7.5 ET48 and 18x7.5 ET 38, 5x114.3. Center bore 69-70mm. Will they fit my car? Do you think I will need fender rolling? Also will I need adaptors or rings (Lexus wheels have 60.1mm center bore).
Your help would be appreciated.:lol:
09-07-2020, 01:28 AM #1
phaebo
09-07-2020, 02:05 AM
You definitely need center rings for 60.1mm
I think the et38 wheels will fit perfect at the rear. But i am not sur about the fronts maybe they will hit the coilovers on the inside. Maybe a little spacer will be enough
I dont think you need to roll. Maybe just a bit plastic modification on the front
phaebo
09-07-2020, 02:05 AM #2
09-07-2020, 02:33 AM
Et38 is for the front wheels due to big calipers
09-07-2020, 02:33 AM #3
Fry-Up
11-07-2020, 10:33 PM
I reckon the et48 would fit at the back too no problems, but I'd probably use spacers to push them out a little to match the front
Fry-Up
11-07-2020, 10:33 PM #4
Views 284
20-01-2024, 07:39 AM
Last Post by cjoseph
Views 869
23-03-2021, 07:29 AM
Last Post by kaykay
Views 374
15-09-2020, 02:23 PM
Views 534
10-06-2018, 07:12 AM
Last Post by Stoney
Views 1,139
07-02-2018, 08:54 AM
Last Post by danielson
Replies 40
Views 2,145
05-01-2018, 08:03 AM
Last Post by reganlives
Views 1,322
29-08-2017, 11:23 AM
Last Post by colinmcr
