JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Lexus IS200 with Altezza Cluster
15-09-2020, 10:51 AM
Hi,
Does anyone know if the Altezza cluster is straight swap for the Lexus IS200 (TRD, Modellista or Kouki type)? Is it just plug&play or re-wiring is needed? Does all the functions of the Altezza cluster operate normal or not?
15-09-2020, 10:51 AM #1
Hi,
15-09-2020, 11:02 AM
Stav had an Altezza cluster briefly and I believe he had an issue with the rev counter as it was from a 4-cyl car. Assuming you mean an Altezza RS200 anyway. Stav got round it by modifying the output from his Link ECU - if you're not running a custom ECU you can get around it with a Dakota signal interface.
15-09-2020, 11:02 AM #2
15-09-2020, 11:40 AM
I had an Altezza (Modellista) speedo in mine for a while, it's all plug and play. But you will need converters to change the 4 cylinder output to 6 cylinders, and also Km/h to MPH. (same converter can be used for both)
Also the lights do come on, but for some reason the dimmer switch does not dim them anymore.
And the speedo I got had an oil pressure gauge instead of MPG which did not function.
Edited 27-10-2013, 09:17 PM by sprinter2012.
15-09-2020, 11:40 AM #3
15-09-2020, 11:48 AM
Thanks all for the information
15-09-2020, 11:48 AM #4
15-09-2020, 02:23 PM
manual to manual only as far as i know.
15-09-2020, 02:23 PM #5
Views 252
20-01-2024, 07:39 AM
Last Post by cjoseph
Views 928
28-05-2023, 02:46 PM
Last Post by bigdave1701
Views 240
07-02-2023, 12:35 AM
Replies 47
Views 3,023
08-12-2022, 09:37 AM
Views 283
20-04-2021, 11:46 PM
Last Post by lexusdaydreaming
Views 738
23-03-2021, 07:29 AM
Last Post by kaykay
Replies 31
Views 1,825
25-07-2020, 07:50 AM
Views 239
11-07-2020, 10:33 PM
Last Post by Fry-Up
