JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning I got something you want :) IS-F push Start IS200
Pages (5): 1 2 3 4 5 Next
19-02-2017, 05:47 AM
IS200 Push start switch from the IS-F
So i picked this switch up from the states should have been over £150 in the uk just for the switch Confusedcared:
The problem is that it doesnt just plug in to the car it requires custom circuitry, i cant take credit for the circuit as a guy in denmark designed a similar circuit i just adapted it to do what i wanted
here are the pics from birth etc
take one centre console
[Image: 063.jpg]
Remove lighter
[Image: 062.jpg]
Then attack with a dremel
[Image: 065.jpg]
till the switch is tight
[Image: 067.jpg]
I then tested all prongs till i got the desired outputs
[Image: 071.jpg]
[Image: 072.jpg]
[Image: 073.jpg]
i then had some help from the huricane as he was free and we built the circuit
[Image: 069.jpg]
we fully tested the circuit then started work on another that was smaller
[Image: 074.jpg]
[Image: 075.jpg]
[Image: 077.jpg]
[Image: 076.jpg]
19-02-2017, 05:47 AM #1
[Image: 063.jpg]
Remove lighter
[Image: 062.jpg]
[Image: 065.jpg]
[Image: 067.jpg]
[Image: 071.jpg]
[Image: 072.jpg]
[Image: 073.jpg]
[Image: 069.jpg]
[Image: 074.jpg]
[Image: 075.jpg]
[Image: 077.jpg]
[Image: 076.jpg]
19-02-2017, 05:50 AM
wow. that is great i want. think you should start a group buy
19-02-2017, 05:50 AM #2
19-02-2017, 05:51 AM
Now time for the box
we cut a inline fuse in to the box
[Image: 084.jpg]
then started fitting the stuff to the box
[Image: 082.jpg]
[Image: 087.jpg]
[Image: 085.jpg]
[Image: 086.jpg]
[Image: 089.jpg]
Testing in the front room
[Image: th_IMG_0247.jpg]
then fitted to the car
[Image: th_IMG_0256-1.jpg]
i do have all the details on how it all wires up but wont bore the thread with this yet lol:drink:
19-02-2017, 05:51 AM #3
[Image: 084.jpg]
[Image: 082.jpg]
[Image: 087.jpg]
[Image: 085.jpg]
[Image: 086.jpg]
[Image: 089.jpg]
19-02-2017, 05:54 AM
All in all the cost for the circuit and wiring etc would not total more than £75 depending on how you make the board
the switch alone can set you back alot more but the theory is that any switch can be used...
this is the MK2 of the circuit
MK3 will include a Etched PCB Board and a separate relay pack etc
19-02-2017, 05:54 AM #4
19-02-2017, 06:25 AM
Nice job mate.
19-02-2017, 06:25 AM #5
Nice job mate.
19-02-2017, 07:02 AM
Nice. But have you disabled the immobiliser then ? How about the steering lock ?
19-02-2017, 07:02 AM #6
19-02-2017, 07:27 AM
i have an after market alarm so that is the immobiliser i wont go into details of that for the security of the car etc, still have to turn take the steering lock of manually but im working on that.... once i have sussed that out and have a long standing solution then i will removing mine change it and move the switch to the existing key switch location.
19-02-2017, 07:27 AM #7
19-02-2017, 08:38 AM
Nice job mate, so once you sort out the steering lock thing, will it be a proper keyless start like in the IS250 and IS-F? Do you have a proximity sensor for the key or something?
19-02-2017, 08:38 AM #8
Tango
19-02-2017, 08:59 AM
You say it's an IS-F button. Is there a difference between that one and those used on the IS250/350/220D?
Tango
19-02-2017, 08:59 AM #9
19-02-2017, 09:02 AM
Tango You say it's an IS-F button. Is there a difference between that one and those used on the IS250/350/220D?
Lol, I think the same starter button is used across the entire Toyota/Lexus range :biggrin:
19-02-2017, 09:02 AM #10
Views 252
20-01-2024, 07:39 AM
Last Post by cjoseph
Views 928
28-05-2023, 02:46 PM
Last Post by bigdave1701
Views 283
20-04-2021, 11:46 PM
Last Post by lexusdaydreaming
Views 739
23-03-2021, 07:29 AM
Last Post by kaykay
Views 337
15-09-2020, 02:23 PM
Replies 31
Views 1,825
25-07-2020, 07:50 AM
Replies 103
Views 5,816
31-03-2020, 07:02 AM
Last Post by Barry
Views 355
30-10-2019, 05:26 AM
