JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning removing stereo from is200
shafik
08-10-2019, 02:00 AM
Hi guys could somebody please give me a step by step guide on how to remove the stock cd player from an X reg lexus is200 (no sat nav) and to replace with an aftermarket headunit.Pics on how to do this would be great.
Many Thanks
Shaq.Big GriniscoStu::w00t::w00t:
shafik
08-10-2019, 02:00 AM #1
Many Thanks
PETEHAMASAKI
08-10-2019, 02:35 AM
shafik Hi guys could somebody please give me a step by step guide on how to remove the stock cd player from an X reg lexus is200 (no sat nav) and to replace with an aftermarket headunit.Pics on how to do this would be great.
Many Thanks
http://youtu.be/khJVrUaNTDQ
good luck :wink:
PETEHAMASAKI
08-10-2019, 02:35 AM #2
Many Thanks
good luck :wink:
08-10-2019, 03:23 AM
Top Outlaw tip:
Use masking take to protect the dash surround it is so easy to damage and marks are not at all straightforward to remove if at all.
Also putting the gear stick into 6th will help lots for access - for autos move it as far away from the dash as you can.
08-10-2019, 03:23 AM #3
Top Outlaw tip:
Raymond
30-10-2019, 01:01 AM
Cheers for the link.
I expected things to be screwed in but I'll give the yanking technique a go :ohmy:
I need to get the A-pillar cover off too and the glovebox. Do I just yank 'em off?
Raymond
30-10-2019, 01:01 AM #4
jomo
30-10-2019, 01:33 AM
A pillar pops off, glove box has to be pushed in together at the top to allow it to flop out then theres 2 plastic pegs that just slide out so you can remove the box in full.
jomo
30-10-2019, 01:33 AM #5
jomo
30-10-2019, 01:35 AM
Sorry, a pillar has a plastic screw where your feet are.
jomo
30-10-2019, 01:35 AM #6
Raymond
30-10-2019, 04:55 AM
Cheers pal,
It's to run the mic to the rear view mirror of that Parrot thing I asked on LOC.
Raymond
30-10-2019, 04:55 AM #7
Cheers pal,
jomo
30-10-2019, 05:09 AM
Ah got you now.
jomo
30-10-2019, 05:09 AM #8
Ah got you now.
30-10-2019, 05:26 AM
You don't need to remove the A pillar for that necessarily, I just tucked it behind the trim. Just be careful if you have curtain airbags to make sure you don't cross over it.
30-10-2019, 05:26 AM #9
Views 245
20-01-2024, 07:39 AM
Last Post by cjoseph
Views 923
28-05-2023, 02:46 PM
Last Post by bigdave1701
Replies 47
Views 2,992
08-12-2022, 09:37 AM
Views 277
20-04-2021, 11:46 PM
Last Post by lexusdaydreaming
Views 737
23-03-2021, 07:29 AM
Last Post by kaykay
Views 335
15-09-2020, 02:23 PM
Replies 31
Views 1,824
25-07-2020, 07:50 AM
Replies 103
Views 5,757
31-03-2020, 07:02 AM
Last Post by Barry
