JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications TTE Supercharger Install Help!
05-07-2018, 02:45 AM
if memory serves the 2 wires for the ecu will produce a resistance AFAIK so i would check this 1st using a multimeter
it completely slipped my mind to take a photo
oooh oooh
speak to aj get him to open his ecu box up as i left a small snipet of cable on the sensor wire in the car so he can identify the wire this way mate
05-07-2018, 02:45 AM #21
oooh oooh
07-07-2018, 10:35 PM
[Image: downloadje.jpg]
[Image: download1b.jpg]
Uploaded with ImageShack.us
these are the pics aj sent so power is same as the fcd
brown signal wire went into the ecu green with yellow strip
the red with yellow strip went in to the ecu , just about can see is it green with red strip
lookatmybiceps
07-07-2018, 10:35 PM #22
07-07-2018, 10:56 PM
That rings a bell mate
07-07-2018, 10:56 PM #23
rob
09-07-2018, 12:09 AM
Bandit I got a clutch conversion kit from Gord for mine, not sure if he can still get them but might be worth asking? :thumbup1: at the moment i have a home made induction kit fitted with Apexi filter :thumbup1:
the clutch adaptor is from a RAV4 so you can get one from any dealer - they need to look on the parts fiche for it. you will need a T-piece and about 40cm of brake fluid resistant tubing.
rob
09-07-2018, 12:09 AM #24
164
09-07-2018, 02:21 AM
ok just installed it, it kicking out a lot of black smoke and when i turn the engine cuts out and its runing very lumpy it it guna be the chip, not wired right, but there is no ecu light on?
lookatmybiceps
09-07-2018, 02:21 AM #25
09-07-2018, 02:31 AM
if you un wire it the car should run still
09-07-2018, 02:31 AM #26
09-07-2018, 02:32 AM
you just cant drive it above 3k i think it was
09-07-2018, 02:32 AM #27
09-07-2018, 04:19 AM
ah it ok i got a wire wrong seams to run better now will go for a drive to see
lookatmybiceps
09-07-2018, 04:19 AM #28
09-07-2018, 04:21 AM
cool look forward to seeing some more pics of it fitted
09-07-2018, 04:21 AM #29
09-07-2018, 05:56 AM
went for a run the pipe was close to the air con pump scuffed a bit and i think i hit fuel cut, as i floored it in 3gear as speed was picking up it made a woosh sound and it was like i slamed the brakes on for a second, is the chip still not wired right it seems fine apart from this, i conected the 2 senor wires to blue with yellow strip on the ecu and there are 2 wires this color and im prety sure thats how aj had it wired looking at the pics
lookatmybiceps
09-07-2018, 05:56 AM #30
Views 1,690
29-05-2023, 05:08 PM
Last Post by Mikedaddy
Views 723
23-05-2023, 12:26 AM
Last Post by ashj25839
Views 472
06-04-2023, 02:00 AM
Replies 24
Views 938
12-01-2023, 11:53 AM
Views 111
03-01-2023, 01:19 PM
Views 86
27-12-2022, 10:58 PM
Views 415
02-12-2022, 01:57 PM
Views 427
04-11-2022, 05:54 AM
Views 58
30-07-2022, 01:49 PM
