Pages (139): Previous 131 32 33 34 35139 Next
24-08-2018, 05:30 PM
You not talking to me Confusedmoke:
24-08-2018, 05:30 PM #321
24-08-2018, 05:32 PM
So cant you butcher you're old ones and fit all the needed bits to the new seats ??
24-08-2018, 05:32 PM #322
24-08-2018, 05:34 PM
Moley So cant you butcher you're old ones and fit all the needed bits to the new seats ??
The motors are too much effort to be honest mate,
the heated seat parts im unsure about but i think the pads will be simpler
24-08-2018, 05:34 PM #323
29-08-2018, 05:50 PM
Stav, you know you said you have a big turbo? I was just reading this, and saw your turbo at JAE and said A/F 50, which means a 50mm turbo housing doesnt it?
But Rabster's is a A/F 60, does this mean his is bigger than yours?
And Dave Reed's is a A/4 70, which is bigger by 20mm?
So Dave has a bigger turbo than you theoretically?
29-08-2018, 05:50 PM #324
29-08-2018, 06:19 PM
Nope not quite that simple mate.
The turbo's will have said AR not AF or A4
http://www.turbobygarrett.com/turbobygar...102.html#b
Quote:Compressor A/R - Compressor performance is comparatively insensitive to changes in A/R. Larger A/R housings are sometimes used to optimize performance of low boost applications, and smaller A/R are used for high boost applications. However, as this influence of A/R on compressor performance is minor, there are not A/R options available for compressor housings.
29-08-2018, 06:19 PM #325
29-08-2018, 06:23 PM
All our turbo's though i believe are GT30 series Garretts.
Though i'm unsure of the trim etc of both Rabs and Daves.
You can have 2 turbos that look identical from the outside but are HUGELY different inside and produce completely different results
29-08-2018, 06:23 PM #326
29-08-2018, 06:37 PM
Ahh ok mr technical, I did not mean to put a/4, i thought it was a/f though, so nerrr
But anyway, what makes yours bigger than Andrew's or Daves?
29-08-2018, 06:37 PM #327
29-08-2018, 06:40 PM
Dark Samurai Ahh ok mr technical, I did not mean to put a/4, i thought it was a/f though, so nerrr
But anyway, what makes yours bigger than Rabster's or Daves?
Like i said ive no idea what exact turbo Daves and Rabs are so i dont know.
If they will post the details i can tell you the characteristics then, but biggers not necessary better.
29-08-2018, 06:40 PM #328
30-08-2018, 07:08 AM
Sparkystav biggers not necessary better.
It's what you do with it that counts, eh Stav?
30-08-2018, 07:08 AM #329
30-08-2018, 07:38 AM
generally the larger a/r the higher potential top end power however you may lose some spool time. As stav said you can have 2 turbos that are the exact same just with different a/r's which i think is the case in stav's and rabsters unsure on Dave's.
30-08-2018, 07:38 AM #330
Views 359
21-02-2025, 07:55 PM
