JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Help with installing headrest monitors...
Pages (4): Previous 1 2 3 4
07-01-2017, 08:16 AM
#31
momo88 no idea tbh. Ive just bought the car in december. i thought the alternator ( i think) charged the battery while the engine ran?
It does, yes. But if the battery is an old one and is failing (which can be accelerated by cold weather, which we've had a lot of recently !), then it often will not hold much charge. So the alternator charges it up a bit but not very much, and it soon runs out.
I'm not saying this *is* your problem, just if it's an old battery if might not be anything to do with your wiring.
If you have a multimeter you can check the battery, e.g. the voltage when it's off, and also check the current drain when nothing is on (i.e. check nothing is draining the battery except the OEM alarm).
07-01-2017, 08:16 AM #31
momo88
07-01-2017, 03:00 PM
#32
got it working now. Cheers lads! took it for a good 40mins run there after a 10mins charge with my mates car. voltmeter in the dash shows 13ish volts when car is idleing
momo88
07-01-2017, 03:00 PM #32
Views 676
23-01-2021, 12:42 PM
Replies 51
Views 3,233
27-01-2017, 03:25 AM
Views 2,077
01-09-2016, 03:46 AM
