JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza My new supercharger project
Pages (4): Previous 1 2 3 4
30-04-2017, 02:51 AM
#31
James S Could you just not have an incar adjuster for the boost? Turn it up when you want to have a blast and turn it down when you want to save fuel?
My mate has one on his R5 turbo, and it works a treat, not sure whether you can do the same on a supercharger though.
A SC puts strain on the engine, its like running your AC all the time (only more drag), not like a turbo, so having a clutch system will save fuel, but with obvious drawbacks.
The Mclaren SLR takes something like 100BHP just to drive its SC's
Could a micro switch be installed so when the throttle is past a set point the SC kicks in?
Edited 11-06-2010, 12:27 PM by FirebirdPhil.
30-04-2017, 02:51 AM #31
P.Lindblom
02-05-2017, 01:51 PM
#32
2tongues Could a micro switch be installed so when the throttle is past a set point the SC kicks in?
Absolutely Smile Just place the micro switch at the bypass valve.
Here's a video of how the magnetic clutch works when you switch on 12V: http://www.youtube.com/watch?v=ZQ15TteeYiU
P.Lindblom
02-05-2017, 01:51 PM #32
D.F!ANT
04-07-2018, 06:08 AM
#33
Excellent, did you get it installed and running ok, i'm planning on switching my s/c for use in a twincharged setup, nice to see the clutch didn't require anything other then current to operate, I was worried they might require an actual signal!
mad max had this on his ford, sorry 'pursuit special', :wink: not sure bout K.I.T thou!
D.F!ANT
04-07-2018, 06:08 AM #33
04-07-2018, 07:46 AM
#34
Marsdendean Thread Resurrection!!!!
Could you turn the SC off for normal driving, then turn it on when you want a blast, without damaging the engine. What do you do with your fcd setting when the SC is not on?
I believe that was the point of the clutch switch! But no, it should not cause any damage to anything. I would imagine the FCD setting can stay the same? As it's primary purpose is to trick the ECU's high boost safety cutout mechanism into thinking boost levels are acceptable, so with no extra boost from the charger, then it should still be ok? Although Patrick was running his home made TTE Black Box replica on his, and so at low boost (as you would get with charger off) the ECU would see an accurate figure from the sensor, as the TTE BB stops at the max allowed voltage and holds it as the boost increases, whereas the FCD sends a percentage of the real figure to the ECU all the time.
Marsdendean And how have you wired the setup?
I would imagine 2 wires from the clutch to a dash mounted switch, very simple.
D.F!ANT Excellent, did you get it installed and running ok, i'm planning on switching my s/c for use in a twincharged setup, nice to see the clutch didn't require anything other then current to operate, I was worried they might require an actual signal!
I'm pretty sure he had it running just fine. Although the car may now be sold/for sale?
As mentioned on the other thread, your main issue will be to get the switch operating automatically at the correct point, when the turbo takes over. If I haven't already said so.... COOL IDEA! Best of luck with it.
What I would be interested to know, from Patrick... Did you notice any improvement in MPG with this fitted? With no boost, would you not need to put your foot down a bit more to get the same power for normal driving? This may negate any fuel saved by not driving the charger?
04-07-2018, 07:46 AM #34
04-07-2018, 08:19 AM
#35
Stoney As mentioned on the other thread, your main issue will be to get the switch operating automatically at the correct point, when the turbo takes over. If I haven't already said so.... COOL IDEA! Best of luck with it.
simple pressure switch would do the job, there are several in autoclaves to control the pressure build-ups.
04-07-2018, 08:19 AM #35
D.F!ANT
04-07-2018, 09:10 AM
#36
cheers 2tounges, im gonna follow that up on my thread Smile
D.F!ANT
04-07-2018, 09:10 AM #36
Views 492
29-08-2021, 09:59 AM
Views 479
29-08-2020, 07:09 AM
Replies 140
Views 8,216
05-03-2020, 09:02 AM
Last Post by Rolex
Views 208
28-12-2019, 02:56 PM
Last Post by Ste176
Replies 32
Views 1,582
08-09-2019, 10:48 AM
Last Post by sprinter2012
Views 381
01-09-2019, 02:49 AM
Views 972
20-08-2019, 12:01 PM
Last Post by Lance79
Views 715
05-08-2019, 12:42 PM
Last Post by mattlaw
Views 691
02-08-2019, 12:35 AM
Views 528
21-04-2019, 01:19 PM
